Ping problem
i got a network with a firewall mikrotik 192.168.0.10 then 4 hops to a mikrotik ap 192.168.0.11 where our clients connect to .11 via ppoe.
connections between hops are eoip with wlans bridged.
my problem is that using any MT radio i can ping the ip of a client connected to .11 but using my pc or laptop with GW .10 or even .11 i cannot ping any client connected to .11
i have checked my routing tables in windows, no prob. cabling..no prob. pc and laptop are on the same network segment (.117)
this means i cannot ping to a dsntnatted public ip to internal ip either.
have upgraded to 3.3 but same prob.
HELP! :confused:
More detail in how you hop would be useful.
Is other traffic flowing across the network where the pings aren’t?
Josh
thx josh,
i got it sorted out.
the prob was i replaced a back haul link with a ubnt m5 and the bridge in the units wasnt totally transparent.
wasnt a mt prob at all. sorry mt! :wink:
