ping remote host interconnected network
Hello. Maybe it is crazy and simple question but actually I didn’t found the problem. So first of all excuse me for it. But I was wondered if anyone help me about whats the hell with my doing. Logically I think there shouldn’t be problem.
Its so easy And a simple scenario. I have One Mikrotik (RB951) two interface:
LAN: 192.168.100.1 (also is DHCP Server for IP Pool : 192.168.100-100 ~ 192.168.100.200 , and Gateway: 192.168.100.1 for LAN interface)
WAN: 192.168.1.2 (that is Connected to Modem)
Modem: 192.168.1.1
The Client PC is also connected to LAN side and obtain IP correctly from Mikrotik DHCP Server automatically. (Consider it: 192.168.100.101)
I saw that 2 dynamic static route (DAS) is also created automatically in Mikrotik just as soon as the cables were connected.
The simple thing I want is ping to Modem in 192.168.1.1. It reply with “request timed out”. Why it happens?
I also create direct static route in ip route (Dst:192.168.1.1 GW:WAN) but show request timed out while pinging.
also create “Source NAT” from Source:192.168.100.0/24 to Dst: 192.168.0.0/24 (and reverse its path) doesn’t useful. Even factory-reset and reconfiguration doesn’t help.
I remember that previously this was solved. let me know what was wrong about that as your idea? Thanks. Here is also the map:
Client -----------------------------------------Mikrotik-------------------------------Modem
192.168.100.101 192.168.100.1 192.168.1.2 192.168.1.1
Sorry, but I got confused.
MikroTik IP: 192.168.100.1 - clear
DHCP: 192.168.100.100 - 192.168.100.200 - clear
Network: 192.168.100.0/24 - clear
Gateway: 192.168.100.1 - clear
WAN IP: 192.168.1.2 - clear? Is this given by modem’s DHCP or you had to configure it manually?
192.168.0.1 - what is that IP? Is this your public IP that modem receives? Does it mean, you don’t have any public IP?
  1. Can you ping any outside address like 8.8.8.8 ?
  2. Did you setup masquarade?
And pls export your settings
/export hide-sensitive
Dear matiaszon, Many Thanks for reply. I am so sorry. You are completely right. because of just want to ask it fast, I made some fault in the diagram information. But let me adjust it. here is the true information: (I also make my correction in BOLD format)
But here is also about the answer. again I answer it in BOLD Mode:
ADC  192.168.1.0/24     192.168.1.2     ether2-WAN                0
ADC  192.168.100.0/24    192.168.100.1    ether3-LAN                0
By asking about possibility of pinging 8.8.8.8 I ment if you can ping anything outside the modem. But nevermind. I am not 100% sure, what you want to achieve, but I believe, that if you have modem, MT is the router and NAT for your local network.
The simplest way is to log in, get the latest stable firmware and do:
/system reset-configuration
It will configure your device as a router/gateway. WAN port will be configured on ether1 port and ports from ether2 to ether5 and wlan1 will be bridged. It will also configure DHCP on bridge as below:
address of router (all ports bridged - except ether1): 192.168.88.1
network: 192.168.88.0/24
gateway: 192.168.88.1
DHCP pool: 192.168.88.10-192.168.88.254
When you do this, connect your modem to ether1 of MikroTik and do the command:
/ip address print detail
Dear matiaszon, Thanks for reply. I’m afraid that I couldn’t exactly what I want. Or my the need was not be understood well.
But However now the problem was SOVED. and I found where is the problem. before I talk about the solution, Let me tell again What Really I Need first of all!
The ONLY Thing I really Need was : PING MODEM DEVICE FROM CLIENT (Just it). NO NEED INTERNET OR OTHER,
It means just successul Ping from 192.168.100.101 TO 192.168.1.1! (I hope it be bright now)
Maybe that fault was about my question, I don’t know. But Let’s consider it as a different way (Please also forget about the Modem Device, because I think maybe that was cause miss understanding).
OK, Let’s think we have ONE Router and TWO Client exactly the same as the previous IP Configuration:
CLIENT#1----RB951-----CLIENT#2    ->
*** “PING REQUEST TIME OUT” IS THE ANSWER IF YOU TRY PING FROM CLIENT #1 TO CLIENT#2!
BUT Why? you also saw the the required route rule is already existed in your RB device automatically right after connect the calbes.
If you also eager to know too, here is the cuase and solution:
Actually The answer is so easy. Its because your CLIENT 1 HAVE Default GW BUT CLIENT 2 HAVE NOT!
CRAZY, ISN’T IT? LOL. but actually CLIENT#2 is a modem. and after I added one static route (for return path) in the modem the ping reply was successful too.
in fact ping and its reply is bi-directional. you may send but may not receive. in the modem device maybe you can not see something the same as Default GW.
so maybe you need to add something like STATIC ROUTE for the return path in Modem, that help the received packet can turn back to RB again. It also depend on your network.
At the previous example I got the result using add 192.168.100.0/24 GW:192.168.1.2.
actually the modem now know what should it do with received packet and reply to.
Thanks anyway. If this help anyone please use KADOS if you find here it of course :smiley:
