hello forum, i got a problem when i try to set automatic the gateway for a route when i set a interface as a gateway the ping with routing table parameter doesn't work, but when i set the gateway manually it works perfect, this is the scenario
it’s ethernet adsl, really it’s a 8 wan balancer, it’s strange cause 7 of them works fine, i double check that all the routes are identical, only change the routing mark and the wan gateway..
why you say that it’s not working good? so what it’s the correct way to make a router with a ethernet dhcp adsl internet conection?
Yes, you’re right, but remember that the gateway i’m talking about are the gateway created manually for the balancing, the routes with specific routing-mark, understand?
in other side, all ethernet has marked the in dhcp client the option add-default-route with differents distance, so when one gateway become unrecheable, mikrotik setup another one, this works perfectly…
