ping RTT on a CCR1036 in BRAS mode (PPPoE server)
Hello!
Here is an interesting statistics on a CCR1036 working as a BRAS (PPPoE server). See the picture:
As you see, ping RTT grows over time and resets on reboot. It may be some kind of a resource leak.
Is this the ping time between the monitoring system and the bras?
Yes, exactly.
Two other CCR1036 show similar pictures:
But two another don’t:
The only difference I see now is that ccr0, ccr1 and ccr2 have a DHCP server enabled and ccr3-4 don’t. So probably it is not PPPoE server that creates the RTT growth.
Here are corresponding memory usage graphs. Old routeros versions have had a memory leak, but newer ones are not so clear.
