Ping RTT on every 6 packets
Is this normal with RB750, i test with 5.22 and 6rc5? Ping rtt packet always goes higher on packet no. 6th.
C:\Users\fire>ping 192.168.1.1 -t
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time<1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=167ms TTL=64
Reply from 192.168.1.1: bytes=32 time=99ms TTL=64
Reply from 192.168.1.1: bytes=32 time=32ms TTL=64
Reply from 192.168.1.1: bytes=32 time=133ms TTL=64
Reply from 192.168.1.1: bytes=32 time=50ms TTL=64
Ping statistics for 192.168.1.1:
    Packets: Sent = 31, Received = 31, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 0ms, Maximum = 167ms, Average = 15ms
I have exactly this same issue!
Its affecting pings through the Tik as well. Have tried all sorts but I can’t seem to resolve it.
We are seeing this on every v6 rc1-11 versions, it also seems to drop routes for a split second now and then too
