Ping Scripting Question
Greetings.
I’m a Web application developer in my firm and I know a little about Lua programming language and scripting in RouterOS via Winbox and alike.
I would like to create a script witch will execute a remote script on a public-IP server: http://my-ip/gateways/ping-router.php?destination=DOMAIN/IP&ttl=TTL&packloss=PL
ping-router would accept variables:
destination - i.e. google.com or our main gateway
ttl - will get the TTL value from ping results
packloss = will get the PL value from ping results
All data recived by ping-router.php shall be queried in a database, witch I can do quickly and with ease.
Script should for example ping both Google and our gateway so it would have an array of 2 elements witch will repeat the ping action 2 times.
Hope anyone understands what I asked for.
Can anyone write me an example of my request, please?
Thanks in forwards to all. Cheers.
ping script itself is quite easy
:global "received-packets" [/ping "my-address.com" count=2]
Thanks about that, mrz. I appriciate it.
I have a following issue when I connect via ssh from my linuxbox:
EDIT: I execute (for example):
ssh zlatan@10.0.0.253 "/ping google.com count=2"
I get the following output:
ZERO!
Is it a stdout issue or I cannot retrive ping information data via ssh tunel?
Thanks again.
If you can execute the remote script via HTTP GET request, you could use the fetch tool:
/tool fetch mode=http url="http://my-ip/gateways/ping-router.php?destination=DOMAIN/IP&ttl=TTL&packloss=PL" dst-path="results.txt"
The returned data is stored in results.txt.
Then, if results.txt is < 4096 bytes, you can parse this file on the RouterOS:
/file get "results.txt" contents
Note: the ‘url=’ option is available in RouterOS >= 3.23
Add: The only data returned from ping is the number of successful pings:
:put [/ping 192.168.1.1 count=5]
returns 5 if ping reply successful 5 times
thank you very much dssmiktik :slight_smile:
this is just the thing I needed :slight_smile:
don’t forget to give karma :wink:
Again, I need your help.
I done as dssmiktik wrote, but I have to made some corrections in my part:
/tool fetch mode=http url=“http://10.64.43.124/aplikacije/admin/received-packets” dst-path=“results.txt”
I have to use mod_rewrite where my script executes, because “?” is stripped in terminal in mikrotik witch displays current help.
What I do not understand is the point of results.txt file?
Is it the result content handler for contents retrieved from “url” witch I callback ?
I also need some clarification how to have a global varibale and later use it in “url” parameter of /tool fetch for instance:
my variable name is: all_ping_results and it will content the ping results from the ping command
and I call url: /tool fetch mode=http url=“http://10.64.43.124/aplikacije/admin/$all_ping_results” dst-path=“results.txt”
$all_ping_results is the way I wrote it in some other language. So as I pointed I need some info and help on that matter.
Thanks again to all that might help me and I’m very gradefull :slight_smile:
results.txt file holds to contents returned from the requested web page.
Ex.
PHP file:
<?php
	echo ($_GET['host'] . " ping results")
Command:
/tool fetch mode=http url="http://<domain>/test.php?host=myhost" dst-path="results.txt"
results.txt:
myhost ping results
To join strings, use the ‘.’ character inside ‘()’.
Ex.
:global "all_ping_results"
<your code here>
/tool fetch mode=http url=("http://10.64.43.124/aplikacije/admin/" . $"all_ping_results") dst-path="results.txt"
For more scripting help: http://wiki.mikrotik.com/wiki/Manual:Scripting
For more PHP help: http://php.net/manual/en/index.php
Hope this helps.
