In Mikrotik RB951ui-2hnd, I setup 2 WANs and 4 LANs. For the first and second LANs, they access Internet using WAN1. I have attached a printer to the first VLAN. I cannot communicate to the printer from other VLANs. I have tried Google for a month, but I cannot do it. Could you please help me.
Below is my script on the RB951Ui-2HnD
jan/02/1970 14:29:44 by RouterOS 6.34.4
software id = QSI1-GKWK
add name=bridge1
add name=bridgemgt
/interface vlan
add interface=bridge1 name=AAA vlan-id=1100
add interface=bridge1 name=BBB vlan-id=1200
add interface=bridge1 name=CCC vlan-id=1300
add interface=bridge1 name=DDD vlan-id=1400
add name=dhcp_pool1 ranges=192.168.8.2-192.168.8.20
add name=dhcp_pool2 ranges=192.168.3.10-192.168.3.254
add name=dhcp_pool3 ranges=192.168.4.10-192.168.4.254
add name=dhcp_pool4 ranges=192.168.5.10-192.168.5.254
add name=dhcp_pool5 ranges=192.168.6.10-192.168.6.254
add name=dhcp_pool6 ranges=192.168.8.2-192.168.8.20
add address-pool=dhcp_pool2 disabled=no interface=AAA name=dhcp2
add address-pool=dhcp_pool3 disabled=no interface=BBB name=dhcp3
add address-pool=dhcp_pool4 disabled=no interface=CCC name=dhcp4
add address-pool=dhcp_pool5 disabled=no interface=DDD name=dhcp5
add address-pool=dhcp_pool6 disabled=no interface=bridge1 name=dhcp1
add bridge=bridgemgt interface=ether5
add address=192.168.8.1/24 interface=ether3 network=192.168.8.0
add address=192.168.3.1/24 interface=AAA network=192.168.3.0
add address=192.168.4.1/24 interface=BBB network=192.168.4.0
add address=192.168.5.1/24 interface=CCC network=192.168.5.0
add address=192.168.6.1/24 interface=DDD network=192.168.6.0
/ip dhcp-client
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no
interface=ether1
interface=ether2
add address=192.168.3.0/24 gateway=192.168.3.1
add address=192.168.4.0/24 gateway=192.168.4.1
add address=192.168.5.0/24 gateway=192.168.5.1
add address=192.168.6.0/24 gateway=192.168.6.1
add address=192.168.8.0/24 dns-server=8.8.8.8,8.8.4.4 gateway=192.168.8.1
set servers=8.8.8.8,8.8.4.4
/ip firewall mangle
add action=mark-routing chain=prerouting new-routing-mark=GETCSWAN1
src-address=192.168.3.0/24
add action=mark-routing chain=prerouting new-routing-mark=GETDSUWAN1
src-address=192.168.4.0/24
add action=mark-routing chain=prerouting new-routing-mark=GETGUESTWAN2
src-address=192.168.5.0/24
add action=mark-routing chain=prerouting new-routing-mark=GETSTAFFWAN2
src-address=192.168.6.0/24
add action=masquerade chain=srcnat out-interface=ether2
/ip firewall service-port
set ftp disabled=yes
set tftp disabled=yes
set irc disabled=yes
set h323 disabled=yes
set pptp disabled=yes
add distance=1 gateway=192.168.1.1 routing-mark=GETCSWAN1
add distance=1 gateway=192.168.1.1 routing-mark=GETDSUWAN1
add distance=1 gateway=192.168.2.1 routing-mark=GETGUESTWAN2
add distance=1 gateway=192.168.2.1 routing-mark=GETSTAFFWAN2
/ip service
set telnet disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system leds
set 5 interface=wlan1
/system routerboard settings
set protected-routerboot=disabled
