Ping timeout from time to time
I have several routerboards 112 with Mikrotik 2.9.27. On few of them, when I log to Winbox and try to ping some clients from router I receive nothing ?! Neither ping timeout nor reply ?! It looks like it’s blocked ?! It simply don’t work!
It heppening from time to time and when I reboot router everything work fine for some time. Then again it doesn’t work.
Clients have net and can ping router but I can’t from router? It’s very big probem to me, for example, when it stops to work, watchdog tool cant ping wireles interface of router and consider that as a failure, then reboot router.
Any help?
i think, you did ping over unwire…is right.? if yes, i think that user client at that CPE still full traffics. i think you not able pinging or time-out request …
regards
Hasbullah.com
yes I pinging over wireless but my user doesn’t have any traffic at that moments.
oooo…
have you recheck on you firewall icmp or nat for…
did you config your client as yourself..?
or try with mac-ping tool…for investigation..
regards
Hasbullah.com
i really think upgrade to latest.
I had same thing and fixed with upgrade (even tho change log is silent about wireless change)
It worked for me
