i have 2 rbs one with 2 cards one card as a link to other rb and the other card acting as ap, the other board also have 2 xr5 cards one card for station wds for the link and the other for the ap,these three pings are for 3 clients in these 2 ap,there is time out every while in all the clients in both sides knowing that i am making the ping from a wire connected to the link, also i have in the same time timeout ping to the link
Maybe some bad signal / link quality causing disconnections. Check it. Hope you are using 6.32.3 with cm2 package.
Good day, yesterday i upgraded to 6.32.1 and still the same problem,even if i am connected to the main ap with a wire it gives these 2 time out every time
now i will update to 6.32.3 and see if i will have the same results
even with the update still the problem exists ,any help please
