Ping Timeouts? Routerproblems?
Hello everyone,
after setting up a MT 750G with a lot of forum help I had a few days of happiness…no things kind of are getting seriously rough. I have connection problems to the router, a lot of ping time outs, slow connections et cetera. Since the router is reached over a wireless connection, I still think the problem is the wireless part, but my boss thinks otherwise and doubts the router itself.
I’m still new to MT, working my way into it pretty slowly and I’m not sure, if something with my settings is actually wrong.
I know it is a lot to ask, but I’d really appreciate it, if someone could look through my config to check wether there are possible settings that might cause the ping timeout problems.
Perhabs some additional information: We are working as a little local internet service provider, using radio systems for our customers. As I mentioned before, I still think the radio systems or something else cause the problems, but my boss things differently. But since we are a local isp, we need that bandwidth limitation per client IP. And I’m not sure, if the bandwidth management I set up is a) correct b) so inefficient, that it might be the reason of the problems.
That’s it so far…if any more information is required, I’ll try to answer as soon as possible.
So here is the complete output of /export:
[admin@MT1] > /export
# may/24/2011 18:29:14 by RouterOS 4.11
# software id = 816T-4G1U
set 0 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:77:6E master-port=none mtu=1500 name=ether1-WAN1-Kabel100 speed=\
    1Gbps
set 1 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:77:6F master-port=none mtu=1500 name=ether2-WAN2-Kabel32 speed=\
    100Mbps
set 2 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:77:70 master-port=none mtu=1500 name=ether3-LAN1-master speed=\
    100Mbps
set 3 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:77:71 master-port=ether3-LAN1-master mtu=1500 name=\
    ether4-LAN2-slave speed=100Mbps
set 4 arp=enabled auto-negotiation=yes bandwidth=unlimited/unlimited comment="" disabled=no full-duplex=yes l2mtu=1524 mac-address=00:0C:42:A5:77:72 master-port=ether3-LAN1-master mtu=1500 name=\
    ether5-LAN3-slave speed=100Mbps
/interface ethernet switch
set switch1 mirror-source=none mirror-target=none name=switch1
/ip hotspot profile
set default dns-name="" hotspot-address=0.0.0.0 html-directory=hotspot http-cookie-lifetime=3d http-proxy=0.0.0.0:0 login-by=cookie,http-chap name=default rate-limit="" smtp-server=0.0.0.0 split-user-domain=no \
    use-radius=no
/ip hotspot user profile
set default idle-timeout=none keepalive-timeout=2m name=default shared-users=1 status-autorefresh=1m transparent-proxy=no
/ip ipsec proposal
set default auth-algorithms=sha1 comment="" disabled=no enc-algorithms=3des lifetime=30m name=default pfs-group=modp1024
/ppp profile
set default change-tcp-mss=yes comment="" name=default only-one=default use-compression=default use-encryption=default use-vj-compression=default
set default-encryption change-tcp-mss=yes comment="" name=default-encryption only-one=default use-compression=default use-encryption=yes use-vj-compression=default
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Total_download parent=ether3-LAN1-master priority=1
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=Total_upload parent=ether1-WAN1-Kabel100 priority=4
/queue type
set default kind=pfifo name=default pfifo-limit=50
set ethernet-default kind=pfifo name=ethernet-default pfifo-limit=50
set wireless-default kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set synchronous-default kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 red-limit=60 red-max-threshold=50 red-min-threshold=10
set hotspot-default kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
add kind=pcq name=pcq_down_16000k pcq-classifier=dst-address pcq-limit=50 pcq-rate=16000000 pcq-total-limit=2000
add kind=pcq name=pcq_down_3000k pcq-classifier=dst-address pcq-limit=50 pcq-rate=3000000 pcq-total-limit=2000
add kind=pcq name=pcq_down_9000k pcq-classifier=dst-address pcq-limit=50 pcq-rate=9000000 pcq-total-limit=2000
add kind=pcq name=pcq_down_6000k pcq-classifier=dst-address pcq-limit=50 pcq-rate=6000000 pcq-total-limit=2000
add kind=pcq name=pcq_up_1600k pcq-classifier=src-address pcq-limit=50 pcq-rate=1600000 pcq-total-limit=2000
add kind=pcq name=pcq_up_600k pcq-classifier=src-address pcq-limit=50 pcq-rate=600000 pcq-total-limit=2000
add kind=pcq name=pcq_up_300k pcq-classifier=src-address pcq-limit=50 pcq-rate=300000 pcq-total-limit=2000
add kind=pcq name=pcq_up_900k pcq-classifier=src-address pcq-limit=50 pcq-rate=900000 pcq-total-limit=2000
set default-small kind=pfifo name=default-small pfifo-limit=10
/queue tree
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=9mbit_download packet-mark=9mbit_traffic parent=Total_download priority=1 queue=pcq_down_9000k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=6mbit_download packet-mark=6mbit_traffic parent=Total_download priority=1 queue=pcq_down_6000k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=3mbit_download packet-mark=3mbit_traffic parent=Total_download priority=1 queue=pcq_down_3000k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=16mbit_download packet-mark=16mbit_traffic parent=Total_download priority=4 queue=pcq_down_16000k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=0,6mbit_upload packet-mark=6mbit_traffic parent=Total_upload priority=1 queue=pcq_up_600k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=0,9mbit_upload packet-mark=9mbit_traffic parent=Total_upload priority=1 queue=pcq_up_900k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=1,6mbit_upload packet-mark=16mbit_traffic parent=Total_upload priority=4 queue=pcq_up_1600k
add burst-limit=0 burst-threshold=0 burst-time=0s disabled=no limit-at=0 max-limit=0 name=0,3mbit_upload packet-mark=3mbit_traffic parent=Total_upload priority=4 queue=pcq_up_300k
/routing bgp instance
set default as=65530 client-to-client-reflection=yes comment="" disabled=no ignore-as-path-len=no name=default out-filter="" redistribute-connected=no redistribute-ospf=no redistribute-other-bgp=no \
    redistribute-rip=no redistribute-static=no router-id=0.0.0.0 routing-table=""
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=auto metric-rip=20 metric-static=20 name=default out-filter=\
    ospf-out redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no redistribute-rip=no redistribute-static=no router-id=0.0.0.0
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=backbone type=default
/snmp
set contact="" enabled=no engine-boots=0 engine-id="" location="" time-window=15 trap-sink=0.0.0.0 trap-version=1
/snmp community
set public address=0.0.0.0/0 authentication-password="" authentication-protocol=MD5 encryption-password="" encryption-protocol=DES name=public read-access=yes security=none write-access=no
/system logging action
set memory memory-lines=100 memory-stop-on-full=no name=memory target=memory
set disk disk-file-count=2 disk-file-name=log disk-lines-per-file=100 disk-stop-on-full=no name=disk target=disk
set echo name=echo remember=yes target=echo
set remote bsd-syslog=no name=remote remote=0.0.0.0:514 src-address=0.0.0.0 syslog-facility=daemon syslog-severity=auto target=remote
/system routerboard settings
set boot-device=nand-if-fail-then-ethernet boot-protocol=bootp cpu-frequency=680MHz force-backup-booter=no silent-boot=no
/user group
add comment="" name=read policy=local,telnet,ssh,reboot,read,test,winbox,password,web,sniff,sensitive,!ftp,!write,!policy
add comment="" name=write policy=local,telnet,ssh,reboot,read,write,test,winbox,password,web,sniff,sensitive,!ftp,!policy
add comment="" name=full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive
/interface bridge settings
set use-ip-firewall=no use-ip-firewall-for-pppoe=no use-ip-firewall-for-vlan=no
set (unknown) vlan-header=leave-as-is vlan-mode=fallback
/interface l2tp-server server
set authentication=pap,chap,mschap1,mschap2 default-profile=default-encryption enabled=no max-mru=1460 max-mtu=1460 mrru=disabled
/interface ovpn-server server
set auth=sha1,md5 certificate=none cipher=blowfish128,aes128 default-profile=default enabled=no keepalive-timeout=60 mac-address=FE:A4:BB:7F:E1:29 max-mtu=1500 mode=ip netmask=24 port=1194 \
    require-client-certificate=no
/interface pptp-server server
set authentication=mschap1,mschap2 default-profile=default-encryption enabled=no keepalive-timeout=30 max-mru=1460 max-mtu=1460 mrru=disabled
/ip accounting
set account-local-traffic=no enabled=no threshold=256
/ip accounting web-access
set accessible-via-web=no address=0.0.0.0/0
add address=192.168.1.3/24 broadcast=192.168.1.255 comment="default configuration" disabled=no interface=ether3-LAN1-master network=192.168.1.0
/ip dhcp-client
add add-default-route=yes comment="default configuration" default-route-distance=1 disabled=no interface=ether1-WAN1-Kabel100 use-peer-dns=yes use-peer-ntp=yes
/ip dhcp-server config
set store-leases-disk=5m
add address=192.168.88.0/24 comment="default configuration" dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes cache-max-ttl=1w cache-size=2048KiB max-udp-packet-size=512 servers=78.42.43.62,82.212.62.62
/ip firewall address-list
add address=192.168.1.17 comment="" disabled=no list=16mbit
add address=192.168.1.18 comment="" disabled=no list=16mbit
add address=192.168.1.19 comment="" disabled=no list=16mbit
add address=192.168.1.20 comment="" disabled=no list=16mbit
add address=192.168.1.21 comment="" disabled=no list=16mbit
add address=192.168.1.23 comment="" disabled=no list=16mbit
add address=192.168.1.24 comment="" disabled=no list=16mbit
add address=192.168.1.25 comment="" disabled=no list=16mbit
add address=192.168.1.26 comment="" disabled=no list=16mbit
add address=192.168.1.27 comment="" disabled=no list=16mbit
add address=192.168.1.28 comment="" disabled=no list=16mbit
add address=192.168.1.29 comment="" disabled=no list=16mbit
add address=192.168.1.30 comment="" disabled=no list=16mbit
add address=192.168.1.31 comment="" disabled=no list=16mbit
add address=192.168.1.32 comment="" disabled=no list=16mbit
add address=192.168.1.33 comment="" disabled=yes list=16mbit
add address=192.168.1.34 comment="" disabled=no list=16mbit
add address=192.168.1.35 comment="" disabled=no list=16mbit
add address=192.168.1.36 comment="" disabled=no list=16mbit
add address=192.168.1.37 comment="" disabled=no list=16mbit
add address=192.168.1.38 comment="" disabled=no list=16mbit
add address=192.168.1.39 comment="" disabled=no list=16mbit
add address=192.168.1.40 comment="" disabled=no list=16mbit
add address=192.168.1.41 comment="" disabled=no list=6mbit
add address=192.168.1.42 comment="" disabled=no list=6mbit
add address=192.168.1.43 comment="" disabled=no list=6mbit
add address=192.168.1.44 comment="" disabled=no list=6mbit
add address=192.168.1.45 comment="" disabled=no list=6mbit
add address=192.168.1.46 comment="" disabled=no list=6mbit
add address=192.168.1.47 comment="" disabled=no list=6mbit
add address=192.168.1.48 comment="" disabled=no list=6mbit
add address=192.168.1.49 comment="" disabled=no list=6mbit
add address=192.168.1.50 comment="" disabled=no list=6mbit
add address=192.168.1.51 comment="" disabled=no list=6mbit
add address=192.168.1.52 comment="" disabled=no list=6mbit
add address=192.168.1.53 comment="" disabled=no list=6mbit
add address=192.168.1.54 comment="" disabled=no list=6mbit
add address=192.168.1.55 comment="" disabled=no list=6mbit
add address=192.168.1.56 comment="" disabled=no list=6mbit
add address=192.168.1.57 comment="" disabled=no list=6mbit
add address=192.168.1.58 comment="" disabled=no list=6mbit
add address=192.168.1.59 comment="" disabled=no list=6mbit
add address=192.168.1.60 comment="" disabled=no list=6mbit
add address=192.168.1.61 comment="" disabled=no list=6mbit
add address=192.168.1.62 comment="" disabled=no list=6mbit
add address=192.168.1.63 comment="" disabled=no list=6mbit
add address=192.168.1.64 comment="" disabled=no list=6mbit
add address=192.168.1.65 comment="" disabled=no list=6mbit
add address=192.168.1.66 comment="" disabled=no list=6mbit
add address=192.168.1.67 comment="" disabled=no list=6mbit
add address=192.168.1.68 comment="" disabled=no list=6mbit
add address=192.168.1.69 comment="" disabled=no list=6mbit
add address=192.168.1.70 comment="" disabled=no list=6mbit
add address=192.168.1.71 comment="" disabled=no list=6mbit
add address=192.168.1.72 comment="" disabled=no list=6mbit
add address=192.168.1.73 comment="" disabled=no list=6mbit
add address=192.168.1.74 comment="" disabled=no list=6mbit
add address=192.168.1.75 comment="" disabled=no list=6mbit
add address=192.168.1.76 comment="" disabled=no list=6mbit
add address=192.168.1.77 comment="" disabled=no list=6mbit
add address=192.168.1.78 comment="" disabled=no list=6mbit
add address=192.168.1.79 comment="" disabled=no list=6mbit
add address=192.168.1.80 comment="" disabled=no list=6mbit
add address=192.168.1.81 comment="" disabled=no list=6mbit
add address=192.168.1.82 comment="" disabled=no list=6mbit
add address=192.168.1.83 comment="" disabled=no list=6mbit
add address=192.168.1.84 comment="" disabled=no list=6mbit
add address=192.168.1.85 comment="" disabled=no list=6mbit
add address=192.168.1.86 comment="" disabled=no list=6mbit
add address=192.168.1.87 comment="" disabled=no list=6mbit
add address=192.168.1.88 comment="" disabled=no list=6mbit
add address=192.168.1.89 comment="" disabled=no list=6mbit
add address=192.168.1.90 comment="" disabled=no list=6mbit
add address=192.168.1.121 comment="" disabled=no list=6mbit
add address=192.168.1.122 comment="" disabled=no list=6mbit
add address=192.168.1.123 comment="" disabled=no list=6mbit
add address=192.168.1.124 comment="" disabled=no list=6mbit
add address=192.168.1.125 comment="" disabled=no list=6mbit
add address=192.168.1.126 comment="" disabled=no list=6mbit
add address=192.168.1.127 comment="" disabled=no list=6mbit
add address=192.168.1.128 comment="" disabled=no list=6mbit
add address=192.168.1.129 comment="" disabled=no list=6mbit
add address=192.168.1.130 comment="" disabled=no list=6mbit
add address=192.168.1.131 comment="" disabled=no list=6mbit
add address=192.168.1.132 comment="" disabled=no list=6mbit
add address=192.168.1.133 comment="" disabled=no list=6mbit
add address=192.168.1.134 comment="" disabled=no list=6mbit
add address=192.168.1.135 comment="" disabled=no list=6mbit
add address=192.168.1.136 comment="" disabled=no list=3mbit
add address=192.168.1.137 comment="" disabled=no list=3mbit
add address=192.168.1.138 comment="" disabled=no list=3mbit
add address=192.168.1.139 comment="" disabled=no list=3mbit
add address=192.168.1.140 comment="" disabled=no list=3mbit
add address=192.168.1.141 comment="" disabled=no list=3mbit
add address=192.168.1.142 comment="" disabled=no list=3mbit
add address=192.168.1.143 comment="" disabled=no list=3mbit
add address=192.168.1.144 comment="" disabled=no list=3mbit
add address=192.168.1.145 comment="" disabled=no list=3mbit
add address=192.168.1.146 comment="" disabled=no list=3mbit
add address=192.168.1.147 comment="" disabled=no list=3mbit
add address=192.168.1.148 comment="" disabled=no list=3mbit
add address=192.168.1.149 comment="" disabled=no list=3mbit
add address=192.168.1.150 comment="" disabled=no list=3mbit
add address=192.168.1.91 comment="" disabled=no list=9mbit
add address=192.168.1.92 comment="" disabled=no list=9mbit
add address=192.168.1.93 comment="" disabled=no list=9mbit
add address=192.168.1.94 comment="" disabled=no list=9mbit
add address=192.168.1.95 comment="" disabled=no list=9mbit
add address=192.168.1.96 comment="" disabled=no list=9mbit
add address=192.168.1.97 comment="" disabled=no list=9mbit
add address=192.168.1.98 comment="" disabled=no list=9mbit
add address=192.168.1.99 comment="" disabled=no list=9mbit
add address=192.168.1.100 comment="" disabled=no list=9mbit
add address=192.168.1.101 comment="" disabled=no list=9mbit
add address=192.168.1.102 comment="" disabled=no list=9mbit
add address=192.168.1.103 comment="" disabled=no list=9mbit
add address=192.168.1.104 comment="" disabled=no list=9mbit
add address=192.168.1.105 comment="" disabled=no list=9mbit
add address=192.168.1.106 comment="" disabled=no list=9mbit
add address=192.168.1.107 comment="" disabled=no list=9mbit
add address=192.168.1.108 comment="" disabled=no list=9mbit
add address=192.168.1.109 comment="" disabled=no list=9mbit
add address=192.168.1.110 comment="" disabled=no list=9mbit
add address=192.168.1.111 comment="" disabled=no list=9mbit
add address=192.168.1.112 comment="" disabled=no list=9mbit
add address=192.168.1.113 comment="" disabled=no list=9mbit
add address=192.168.1.114 comment="" disabled=no list=9mbit
add address=192.168.1.115 comment="" disabled=no list=9mbit
add address=192.168.1.116 comment="" disabled=no list=9mbit
add address=192.168.1.117 comment="" disabled=no list=9mbit
add address=192.168.1.118 comment="" disabled=no list=9mbit
add address=192.168.1.119 comment="" disabled=no list=9mbit
add address=192.168.1.120 comment="" disabled=no list=9mbit
add address=192.168.1.16 comment="" disabled=no list=16mbit
add address=192.168.1.22 comment="" disabled=no list=16mbit
add address=192.168.1.251 comment="" disabled=no list=3mbit
set enabled=yes generic-timeout=10m icmp-timeout=10s tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s tcp-syn-received-timeout=5s \
    tcp-syn-sent-timeout=5s tcp-syncookie=no tcp-time-wait-timeout=10s udp-stream-timeout=3m udp-timeout=10s
add action=accept chain=input comment="default configuration" disabled=no protocol=icmp
add action=accept chain=input comment="default configuration" connection-state=established disabled=no in-interface=ether1-WAN1-Kabel100
add action=accept chain=input comment="default configuration" connection-state=related disabled=no in-interface=ether1-WAN1-Kabel100
add action=drop chain=input comment="default configuration" disabled=no in-interface=ether1-WAN1-Kabel100
/ip firewall mangle
add action=mark-packet chain=forward comment=16mbit disabled=no dst-address-list=16mbit new-packet-mark=16mbit_traffic passthrough=yes
add action=mark-packet chain=forward comment=9mbit disabled=no dst-address-list=9mbit new-packet-mark=9mbit_traffic passthrough=yes
add action=mark-packet chain=forward comment=6mbit disabled=no dst-address-list=6mbit new-packet-mark=6mbit_traffic passthrough=yes
add action=mark-packet chain=forward comment=3mbit disabled=no dst-address-list=3mbit new-packet-mark=3mbit_traffic passthrough=yes
add action=masquerade chain=srcnat comment="default configuration" disabled=no out-interface=ether1-WAN1-Kabel100
add action=dst-nat chain=dstnat comment="DMZ 1" disabled=no dst-address=I.CHANGED.THAT.IP to-addresses=192.168.1.21
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=no ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061
set pptp disabled=no
/ip hotspot service-port
/ip neighbor discovery
set ether1-WAN1-Kabel100 discover=no
set ether2-WAN2-Kabel32 discover=no
set ether3-LAN1-master discover=yes
set ether4-LAN2-slave discover=yes
set ether5-LAN3-slave discover=yes
/ip proxy
set always-from-cache=no cache-administrator=webmaster cache-hit-dscp=4 cache-on-disk=no enabled=no max-cache-size=none max-client-connections=600 max-fresh-time=3d max-server-connections=600 parent-proxy=\
    0.0.0.0 parent-proxy-port=0 port=8080 serialize-connections=no src-address=0.0.0.0
add comment="" disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=ether1-WAN1-Kabel100 routing-mark=viaWAN1 scope=30 target-scope=10
add comment="" disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=ether2-WAN2-Kabel32 routing-mark=viaWAN2 scope=30 target-scope=10
/ip service
set telnet address=192.168.1.0/24 disabled=yes port=23
set ftp address=192.168.1.0/24 disabled=no port=21
set www address=192.168.1.0/24 disabled=yes port=80
set ssh address=0.0.0.0/0 disabled=no port=22
set www-ssl address=0.0.0.0/0 certificate=none disabled=yes port=443
set api address=0.0.0.0/0 disabled=yes port=8728
set winbox address=0.0.0.0/0 disabled=no port=8291
/ip socks
set connection-idle-timeout=2m enabled=no max-connections=200 port=1080
/ip traffic-flow
set active-flow-timeout=30m cache-entries=4k enabled=yes inactive-flow-timeout=15s interfaces=all
/ip upnp
set allow-disable-external-interface=yes enabled=no show-dummy-rule=yes
/mpls
set dynamic-label-range=16-1048575 propagate-ttl=yes
/mpls interface
add comment="" disabled=no interface=all mpls-mtu=1508
/mpls ldp
set distribute-for-default-route=no enabled=no hop-limit=255 loop-detect=no lsr-id=0.0.0.0 path-vector-limit=255 transport-address=0.0.0.0 use-explicit-null=no
/ppp aaa
set accounting=yes interim-update=0s use-radius=no
/queue interface
set ether1-WAN1-Kabel100 queue=ethernet-default
set ether2-WAN2-Kabel32 queue=ethernet-default
set ether3-LAN1-master queue=ethernet-default
set ether4-LAN2-slave queue=ethernet-default
set ether5-LAN3-slave queue=ethernet-default
/radius incoming
set accept=no port=3799
/routing bfd interface
set all comment="" disabled=no interface=all interval=0.2sec min-rx=0.2sec multiplier=5
/routing mme
set bidirectional-timeout=2 gateway-class=none gateway-keepalive=1m gateway-selection=no-gateway origination-interval=5s preferred-gateway=0.0.0.0 timeout=1m ttl=50
/routing rip
set distribute-default=never garbage-timer=2m metric-bgp=1 metric-connected=1 metric-default=1 metric-ospf=1 metric-static=1 redistribute-bgp=no redistribute-connected=no redistribute-ospf=no \
    redistribute-static=no routing-table=main timeout-timer=3m update-timer=30s
/store
add comment="" disabled=no disk=system name=web-proxy1 type=web-proxy
/system clock
/system clock manual
set dst-delta=+00:00 dst-end="jan/01/1970 00:00:00" dst-start="jan/01/1970 00:00:00" time-zone=+00:00
/system console
add disabled=no term=vt102
/system health
set
/system identity
set name=MT1
/system logging
add action=memory disabled=no prefix="" topics=info
add action=memory disabled=no prefix="" topics=error
add action=memory disabled=no prefix="" topics=warning
add action=echo disabled=no prefix="" topics=critical
/system note
set note="" show-at-login=yes
/system ntp client
set enabled=yes mode=unicast primary-ntp=134.130.4.17 secondary-ntp=0.0.0.0
/system upgrade mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=0.0.0.0 user=""
/system watchdog
set auto-send-supout=no automatic-supout=yes no-ping-delay=5m watch-address=none watchdog-timer=yes
/tool bandwidth-server
set allocate-udp-ports-from=2000 authenticate=yes enabled=yes max-sessions=100
/tool e-mail
set from=<> password="" server=0.0.0.0:25 username=""
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
add disabled=no interface=ether2-WAN2-Kabel32
add disabled=no interface=ether3-LAN1-master
add disabled=no interface=ether4-LAN2-slave
add disabled=no interface=ether5-LAN3-slave
/tool mac-server ping
set enabled=yes
/tool sms
set allowed-number="" channel=0 keep-max-sms=0 receive-enabled=no secret=""
/tool sniffer
set file-limit=10 file-name="" filter-address1=0.0.0.0/0:0-65535 filter-address2=0.0.0.0/0:0-65535 filter-protocol=ip-only filter-stream=yes interface=all memory-limit=10 memory-scroll=no only-headers=no \
    streaming-enabled=no streaming-server=0.0.0.0
/tool traffic-monitor
add comment="" disabled=no interface=ether1-WAN1-Kabel100 name=tmon1 on-event="" threshold=0 traffic=transmitted trigger=above
/user aaa
set accounting=yes default-group=read interim-update=0s use-radius=no
OK, the problem points more and more towards the MT 750G, I’m still not sure, what the reason is, but here is the situation: We tested several connections from other routers running in the same network (remember its a radio link system). Everything ran fine until I started pinging the router I have these problems with. Suddenly all the ping times within the whole systems rose up, timeouts got more frequent et cetera.
I’ll try to replace it to verify the problem. First with another router, to make sure it’s not the radio link to that station and then with another MT 750G.
Because you exported everything it makes it hard to determine what features you’re actually using. Any chance of cutting that down to the relevant information, and adding a network diagram?
Generally speaking the behavior (you ping one node and suddenly the entire network slows down) to me points to a bridging loop somewhere. You do appear to be running the switch chip, which makes the router act as a wire speed bridge.
Sorry for the late reply once again. Everything is upsidedown here, total confusion - never a good situation to work in :wink:
Right now I’ll leave it at that, thanks for your reply/concern fewi, but it seems the MT is not the problem yet again. I’ll come back to it, if the problems rise up again and I’ll check the config then. Need to figure out dual wan and ovpn ipsec first :slight_smile:
