Hi is ping normal! After a few pings it start to re-ping the same replay. See here!
I did a test to ping from other device to upgraded device. It is the same!
Why? Was ok before! There is two R52HN on it in ap-bridge.
Thx
Thx
From one of my linux servers in the network. It is the same to the device. The strange thing is only to device but it does not happen to it client by wifi.
root@gladiador:~$ ping 10.0.0.30
PING 10.0.0.30 (10.0.0.30) 56(84) bytes of data.
64 bytes from 10.0.0.30: icmp_req=1 ttl=30 time=29.2 ms
64 bytes from 10.0.0.30: icmp_req=1 ttl=30 time=37.9 ms (DUP!)
64 bytes from 10.0.0.30: icmp_req=2 ttl=30 time=9.60 ms
64 bytes from 10.0.0.30: icmp_req=3 ttl=30 time=19.0 ms
64 bytes from 10.0.0.30: icmp_req=3 ttl=30 time=22.9 ms (DUP!)
64 bytes from 10.0.0.30: icmp_req=4 ttl=30 time=7.38 ms
64 bytes from 10.0.0.30: icmp_req=5 ttl=30 time=7.70 ms
64 bytes from 10.0.0.30: icmp_req=6 ttl=30 time=12.1 ms
64 bytes from 10.0.0.30: icmp_req=6 ttl=30 time=22.7 ms (DUP!)
64 bytes from 10.0.0.30: icmp_req=7 ttl=30 time=6.70 ms
64 bytes from 10.0.0.30: icmp_req=7 ttl=30 time=11.2 ms (DUP!)
64 bytes from 10.0.0.30: icmp_req=8 ttl=30 time=7.70 ms
64 bytes from 10.0.0.30: icmp_req=9 ttl=30 time=4.88 ms
64 bytes from 10.0.0.30: icmp_req=10 ttl=30 time=6.39 ms
64 bytes from 10.0.0.30: icmp_req=11 ttl=30 time=26.0 ms
64 bytes from 10.0.0.30: icmp_req=12 ttl=30 time=2.86 ms
64 bytes from 10.0.0.30: icmp_req=12 ttl=30 time=5.90 ms (DUP!)
64 bytes from 10.0.0.30: icmp_req=13 ttl=30 time=8.45 ms
64 bytes from 10.0.0.30: icmp_req=13 ttl=30 time=23.9 ms (DUP!)
64 bytes from 10.0.0.30: icmp_req=14 ttl=30 time=5.77 ms
64 bytes from 10.0.0.30: icmp_req=15 ttl=30 time=5.89 ms
64 bytes from 10.0.0.30: icmp_req=16 ttl=30 time=5.88 ms
64 bytes from 10.0.0.30: icmp_req=17 ttl=30 time=38.6 ms
64 bytes from 10.0.0.30: icmp_req=18 ttl=30 time=7.28 ms
64 bytes from 10.0.0.30: icmp_req=19 ttl=30 time=6.74 ms
^C
— 10.0.0.30 ping statistics —
19 packets transmitted, 19 received, +6 duplicates, 0% packet loss, time 17999ms
rtt min/avg/max/mdev = 2.861/13.726/38.611/10.394 ms
this pings are reaching ether1 not wireless pings.
I need the mipsbe 5.11 npk for downgrade to last version. Where can I download it?
It is a bug for RB433uah! I did a downgrade to 5.11 and now it is ok again.
I still have this problem in many device with 5.24.
Please! How can I solve it?
He has the same problem. http://forum.mikrotik.com/t/how-to-see-ping-seq-in-terminal/63495/1
Duplicate ping responses can be caused by:
Thanks! I have check already. It only happens after upgrade to 5.24. Before at 5.11 It did not appear.
