thanks a lot for your suggestions.
Meanwhile I have sucessfully set up the usual lab-scenario for my students (http://dt.wara.de/pdf/its/netzwerkTechnik/routing/topologie.pdf) with 3 other routers running OS-versions 6.15 and 6.36.1
ospf is running fine: all routes show up in the tables.
With the routers running OS 6.40.5 I have no success:
I simplified the setup to two routers: R1-ether3----192.168.20.0/30—ether4-R2
telnet and ssh - services are running, I can telnet/ssh from any host to interface ether2 on 192.168.88.1. But from one router I cannot connect to the next one. ICMP packets are transmitted.
At least I would expect on R1 to see R2 as an OSPF-neighbour an vice versa, but there are no neighbours on any router. Both are endlessly sending HELLO-packets. log-data and configuration are attached.
How can I dump incoming frames on a router? Is there anything like tcpdump?
Best regards
Michael
01:22:08 system,info device changed by admin
01:22:11 interface,info ether4 link up (speed 1G, full duplex)
01:22:11 route,ospf,debug Starting OSPFv2 on ether4 (192.168.20.2)
01:22:11 route,ospf,debug area=backbone
01:22:11 route,ospf,debug Opening IPv4 multicast socket
01:22:11 route,ospf,debug ether4 (192.168.20.2): interface event
01:22:11 route,ospf,debug event=OSPF_IFE_UP
01:22:11 route,ospf,debug state=Down
01:22:11 route,ospf,debug State change on ether4 (192.168.20.2) from Down to Waiting
01:22:11 route,ospf,debug Originate Router LSA
01:22:11 route,ospf,debug Installing an LSA
01:22:11 route,ospf,debug lsa=Router LSA id=255.255.255.2 originator=255.255.255.2 seqnum=0x80000001
01:22:11 route,ospf,debug Flooding an LSA
01:22:11 route,ospf,debug Deferring LSA origination
01:22:11 route,ospf,debug type=Router LSA
01:22:11 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:22:12 route,ospf,debug Recalculating all OSPFv2 intra-area routes
01:22:12 route,ospf,debug Recalculating all inter-area routes
01:22:12 route,ospf,debug summary-area=backbone
01:22:12 route,ospf,debug Recalculating AS-external routes
01:22:16 route,ospf,debug Originate Router LSA
01:22:16 route,ospf,debug area=backbone
01:22:21 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:22:31 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:22:41 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:22:51 route,ospf,debug ether4 (192.168.20.2): interface event
01:22:51 route,ospf,debug event=OSPF_IFE_WAIT_TIMER
01:22:51 route,ospf,debug state=Waiting
01:22:51 route,ospf,debug DR elections on ether4 (192.168.20.2):
01:22:51 route,ospf,debug existing DR=0.0.0.0
01:22:51 route,ospf,debug existing BDR=0.0.0.0
01:22:51 route,ospf,debug After first elections:
01:22:51 route,ospf,debug DR=192.168.20.2
01:22:51 route,ospf,debug BDR=192.168.20.2
01:22:51 route,ospf,debug After second elections:
01:22:51 route,ospf,debug BDR=0.0.0.0
01:22:51 route,ospf,debug Interface ether4 (192.168.20.2) becomes Designated Router
01:22:51 route,ospf,debug Designated Router changed
01:22:51 route,ospf,debug old=0.0.0.0
01:22:51 route,ospf,debug new=192.168.20.2
01:22:51 route,ospf,debug Originate Router LSA
01:22:51 route,ospf,debug area=backbone
01:22:51 route,ospf,debug State change on ether4 (192.168.20.2) from Waiting to Designated Router
01:22:51 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:23:01 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:23:11 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:23:21 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:23:31 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:23:41 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:23:51 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:24:01 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:24:11 route,ospf,debug SEND: Hello 192.168.20.2 → 224.0.0.5 on ether4
01:24:21 route,ospf,debug SEND: Hello 192.168.20.2 → 22
[admin@R2] > export compact
jan/02/1970 02:38:31 by RouterOS 6.40.5
software id = Y1BB-ZA9H
model = 951G-2HnD
serial number = 4F4304AD953C
add admin-mac=4C:5E:0C:B1:74:79 auto-mac=no comment=defconf name=bridge
add name=loopback
set [ find default-name=ether2 ] name=ether2-master
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce disabled=no distance=indoors frequency=auto
mode=ap-bridge ssid=MikroTik-B1747D wireless-protocol=802.11
/ip neighbor discovery
set ether1 discover=no
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/routing ospf instance
set [ find default=yes ] router-id=255.255.255.2
add bridge=bridge comment=defconf interface=ether2-master
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
add address=192.168.20.2/30 interface=ether4 network=192.168.20.0
add address=255.255.255.2 interface=loopback network=255.255.255.2
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input comment=“defconf: accept established,related,untracked” connection-state=
add action=drop chain=input comment=“defconf: drop invalid” connection-state=invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept in ipsec policy” ipsec-policy=in,ipsec
add action=accept chain=forward comment=“defconf: accept out ipsec policy” ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack” connection-state=established,related
add action=accept chain=forward comment=“defconf: accept established,related, untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=invalid
add action=drop chain=forward comment=“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
/ipv6 firewall address-list
add address=::/128 comment=“defconf: unspecified address” list=bad_ipv6
add address=::1/128 comment=“defconf: lo” list=bad_ipv6
add address=fec0::/10 comment=“defconf: site-local” list=bad_ipv6
add address=::ffff:0.0.0.0/96 comment=“defconf: ipv4-mapped” list=bad_ipv6
add address=::/96 comment=“defconf: ipv4 compat” list=bad_ipv6
add address=2001:db8::/32 comment=“defconf: documentation” list=bad_ipv6
add address=2001:10::/28 comment=“defconf: ORCHID” list=bad_ipv6
add address=3ffe::/16 comment=“defconf: 6bone” list=bad_ipv6
add address=::224.0.0.0/100 comment=“defconf: other” list=bad_ipv6
add address=::127.0.0.0/104 comment=“defconf: other” list=bad_ipv6
add address=::/104 comment=“defconf: other” list=bad_ipv6
add address=::255.0.0.0/104 comment=“defconf: other” list=bad_ipv6
/ipv6 firewall filter
add action=accept chain=input comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=input comment=“defconf: accept UDP traceroute” port=33434-33534 protocol=udp
add action=accept chain=input comment=“defconf: accept DHCPv6-Client prefix delegation.” dst-port=546 protocol=udp
src-address=fe80::/16
add action=accept chain=input comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=input comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=input comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=input comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=input comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
add action=accept chain=forward comment=“defconf: accept established,related,untracked” connection-state=
add action=drop chain=forward comment=“defconf: drop packets with bad src ipv6” src-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: drop packets with bad dst ipv6” dst-address-list=bad_ipv6
add action=drop chain=forward comment=“defconf: rfc4890 drop hop-limit=1” hop-limit=equal:1 protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept ICMPv6” protocol=icmpv6
add action=accept chain=forward comment=“defconf: accept HIP” protocol=139
add action=accept chain=forward comment=“defconf: accept IKE” dst-port=500,4500 protocol=udp
add action=accept chain=forward comment=“defconf: accept ipsec AH” protocol=ipsec-ah
add action=accept chain=forward comment=“defconf: accept ipsec ESP” protocol=ipsec-esp
add action=accept chain=forward comment=“defconf: accept all that matches ipsec policy” ipsec-policy=in,ipsec
add action=drop chain=forward comment=“defconf: drop everything else not coming from LAN” in-interface-list=!LAN
/routing ospf network
add area=backbone network=192.168.20.0/30
/system identity
set name=R2
/system logging
add topics=ospf,!raw
/tool mac-server
add interface=bridge
/tool mac-server mac-winbox
