ping
I have two MT 2.9.46 machines. One on PC, seconf RB133. Both are connected with WDS. Signals are -62/-63, link 5GHz, no other networks. Problem is with Ping, because ping from MT to PC is about 7-8ms, sometimes 17-19ms. No other data is sending over link, CPU utilization about 2-3% on RB133. I have other similar configuratons, and ping is 2-3ms, but with older versions MT. Is there any problem with 2.9.46 Mikrotik version?
no other networks
Are you sure?
What is the noise floor reading?
Sounds like somthing else in your area, perhaps something else using that frequency.
I have no problems with .46, other users on this forum love this version
Yes, I’m sure. Scanning and snooper shows no other networks. This is village, so it’s possible. I have changed channels also, but there is still problem with long response time to ping. Maybe should I try to downgrade MT?
I have downgraded, but nothing changed :frowning: I will try to change RB133 and mPCI card to another one. What do you think?
Now, i know that it’s not link problem. When I am pinging RB133 addresse it replays with 7-9ms! Why pinging itself - it replays with 7-9ms??!
