Pinging and remote access
hey guys great site and a great product
we have started replacing our cisco AP’s with mikrotik 532 and the latest software 3.4 with ubiquiti XR2 radios in them
we are running it as a AP only no routing
it has a public IP address. i can ping it from with in the network but i cant ping it from the outside of the network
also i have set up NTP but when i reboot it it still doesnt keep or get the correct time
anyway your ideas would really help
Check to make sure your ip/subnet are correctly assigned. Did you assign a gateway?
The RB532 does not a battery to keep time when rebooted. With NTP configured it should go out and get the correct time with in about 30 seconds on bootup.
-Louis
you where right the gateway was wrong for whatever reason i changed it and everything is great
thanks guys
