i’d like to implement a router-on-a-stick scenario with a mikrotik router (OS version 6.43.2).
Ether1 - WAN
Ether12 - LAN Trunk to the switch with 6 VLANs.
The VLAN interfaces and ether1 have IP addresses, default route and srcnat masquarde rule is in place.
When i ping 8.8.8.8 from the ether1, it works, but if i ping it from any VLAN interface like (ping 8.8.8.8 interface=VLAN3), all I get is timeout.
Pinging other VLAN’s gateways from a VLAN interface also not working.
Later on I have to enable communication between hosts in different VLANs.
Is this configuration a good start?
set [ find default-name=ether1 ] comment=WAN speed=100Mbps
set [ find default-name=ether12 ] comment=“LAN Trunk to DLINK” speed=100Mbps
/interface vlan
add interface=ether12 name=VLAN1 vlan-id=1
add interface=ether12 name=VLAN2 vlan-id=2
add interface=ether12 name=VLAN3 vlan-id=3
add interface=ether12 name=VLAN4 vlan-id=4
add interface=ether12 name=VLAN5 vlan-id=5
add interface=ether12 name=VLAN6 vlan-id=6
/ip settings
set rp-filter=strict
add address=1.2.3.167/24 comment=WAN interface=ether1 network=1.2.3.0
add address=192.168.1.254/24 interface=VLAN1 network=192.168.1.0
add address=192.168.2.254/24 interface=VLAN2 network=192.168.2.0
add address=192.168.3.254/24 interface=VLAN3 network=192.168.3.0
add address=192.168.4.254/24 interface=VLAN3 network=192.168.4.0
add address=192.168.5.254/24 interface=VLAN5 network=192.168.5.0
add address=192.168.6.254/24 interface=VLAN6 network=192.168.6.0
set servers=8.8.8.8
add action=masquerade chain=srcnat log=yes log-prefix=MASQ
add distance=1 gateway=1.2.3.1
