I have the default firewall rules running on my router. Only thing I added is the “fasttrack” feature.
Not having good idea about how ping should work, here’s my question.
Is is ok form my router to return reply if I ping my IP from outside of my network?
Here’s my firewall rules.
# may/24/2019 12:18:14 by RouterOS 6.45beta50
# software id = S1MG-NEED
# model = RouterBOARD 750G r3
# serial number = xxxxxxxxxxxxx
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=Bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
d this subnet before enable it" list=Bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=Bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=Bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
need this subnet before enable it" list=Bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=Bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
Bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=Bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=Bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=Bogons
add address=224.0.0.0/4 comment=\
"MC, Class D, IANA # Check if you need this subnet before enable it" \
list=Bogons
add action=accept chain=forward comment="defconf: accept established,related" \
add action=fasttrack-connection chain=forward connection-state=\
established,related
connection-state=invalid
add action=accept chain=input port=69 protocol=udp
add action=accept chain=forward port=69 protocol=udp
connection-state=new in-interface=ether1
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
Bogons
add action=accept chain=input connection-state=established
add action=accept chain=input connection-state=related
add action=drop chain=input in-interface=ether1
add action=accept chain=forward connection-state=established,related
