In the terminal you can do something like the following:
/file remove [find type="backup"]
which works perfectly. Is there anyway to do this using the API?
/file/remove
?type="backup"
doesn’t seem to work.
Thanks a lot.
/file/remove
?type="backup"
Thanks a lot.
