Hi!
When messing around with bridge vlan filtering, there is a nice plan B. Install the code below to your switch with correct bridge name and it will help you when requested so.
/system scheduler
# nice feature to automatically unlock the switch from bad vlan config
add name=plan-B on-event="/interface bridge set bridge vlan-filtering=no" \
policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=nov/11/2018 start-time=16:20:00
Set the start date and time of plan-B to 5 minutes ahead of current time just before issuing command:
/interface bridge set bridge vlan-filtering=yes
In case you have misconfigured bridge vlan filtering, then after 5 minutes you will have your access back to the switch.
Source (Andis Āriņš. VLAN processing in New bridge implementation): https://youtu.be/ZMMpza-O7_w?t=2045
