Planned support for ZTE MF626 HSDPA USB Modem
Are there any plans for support for the ZTE MF626 HSDPA USB Modem. The device is badged by Telstra in Australia and is in common usage as a general purpose USB modem. Reading between the lines it appears similar to the other existing MF62x devices.
This would be a readily available and good low cost match to the new RB433UAH.
just make a supout.rif file in the device where you have attached this, and send to support
Thanks Normis, shall do. The Rb is due in the country in a week or so.
Hello Normis
ROS tested at 3.24
My Huawei e226 runs on x86 and rb/433uah
My ZTE mf626 runs on x86 and not rb/433uah deted stores
Thank you
IDC
make the support output file and send it to support@mikrotik.com
one support output file from x86 and one after you put that in the RB433uah
