There are various ways of handling this, herewith our method:
Drop traffic from blacklisted sources without consuming conntrack table entries:
/ip firewall raw
add action=accept chain=prerouting comment="Failsafe - allow CDP:" dst-address=255.255.255.255 dst-port=5678 protocol=udp
add action=accept chain=prerouting comment="Failsafe - allow mactelnet:" dst-address=255.255.255.255 dst-port=20561 protocol=udp src-address=0.0.0.0
add action=drop chain=prerouting comment="Drop - from 'black_list' address list:" src-address-list=black_list
IPs and subnets to exempt from blacklisting:
/ip firewall address-list
add address=54.19.34.24/29 comment="Office:" list=management
add address=192.168.10.0/24 comment="Home:" list=management
Ultimately accept the connection, but add source IP to stage1, if it doesn’t exist in ‘management’ address list. Add to stage2 if it exists in stage1, stage3 if it’s in stage2 or add to ‘black_list’ if it’s in stage3. Four connections within 1 minute will result in the source IP being blacklisted for 24 hours:
add action=add-src-to-address-list address-list=black_list address-list-timeout=1d chain=brutecheck comment="Brute Force Protection:" src-address-list=brute_stage3
add action=add-src-to-address-list address-list=brute_stage3 address-list-timeout=1m chain=brutecheck src-address-list=brute_stage2
add action=add-src-to-address-list address-list=brute_stage2 address-list-timeout=1m chain=brutecheck src-address-list=brute_stage1
add action=add-src-to-address-list address-list=brute_stage1 address-list-timeout=1m chain=brutecheck src-address-list=!management
add action=accept chain=brutecheck
Then simply set the action on any input filter rules to be a jump to ‘brutecheck’, instead of ‘accept’. We do this for tcp/21 (ftp), tcp/22 (ssh), tcp/23 (telnet), tcp/80 (http), tcp/443 (https), tcp/1723 (pptp) and tcp/8291 (winbox). This will black list anyone repeatedly attempting connections to any of these ports and port scanners get listed immediately…:
add action=jump chain=input comment=FTP: connection-state=new dst-port=21 jump-target=brutecheck protocol=tcp
add action=jump chain=input comment=SSH: connection-state=new dst-port=22 jump-target=brutecheck protocol=tcp
add action=jump chain=input comment=Telnet: connection-state=new dst-port=23 jump-target=brutecheck protocol=tcp
add action=jump chain=input comment=HTTP: connection-state=new dst-port=80 jump-target=brutecheck protocol=tcp
add action=jump chain=input comment=HTTPS: connection-state=new dst-port=443 jump-target=brutecheck protocol=tcp
add action=jump chain=input comment="PPTP VPN:" connection-state=new dst-port=1723 jump-target=brutecheck protocol=tcp
add action=jump chain=input comment=Winbox: connection-state=new dst-port=8291 jump-target=brutecheck protocol=tcp
We leave the above honeypot rules active to blacklist connection attempts to lucrative ports even after disabling most of these:
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh port=2222
set api disabled=yes
set api-ssl disabled=yes
