Playstation 3 can not obtain IP from DHCP
RouterOS v6.38.5 (did not upgrade, as it does work for me doing all I need, as with every upgrade, something will change, what worked will work differently or not at all and I will again need to spend time to redo my config, not something I need to spend the time on)
So I did not upgrade!
Connected PS3 after months of gathering dust (probably from before changed to RouterOS, and it simply will time out on trying to get IP via wired connection.
It works fine with Static IP (so what I left it at)
But obviously something is not right
There are mentions for this specific version here having issues with DHCP but over wireless (as stated I use wired)
sebus
