Thanks for suggestion,
Will it work 5 Km Radious ???
Pls suggest what diff between omni and sectorial antina
Regards
Kundal Singh
and what is the best device for Customer end CPE.
kundal
Regards
Kundal Singh
kundal
RB433 (or RB433AH), RB52 (or R52-350), omni antena.
Omni Antenna is not a good idea. Use 3units of 120deg high gain sector antenna instead.
He asked for cheap solution and 3 sector antennas are not cheap for sure.
You can consider to buy the antenna from the www.lanbowan.com.
It’s cost effective and performance is acceptable, no much different with Pac wireless but the pricing wise, very much different.
