Hello everyone,
I got myself a mikrotik router and started a second adventure. I failed the first time. The second time, the tvbox almost made me give up on this adventure. dhcp client saved me. Why did I have to manually add the second wan ip (iptv) in the pppoe client connection? This really bothered me.
You can see my home network in the figure. I am a beginner for mikrotik router. I copied the firewall configuration from the internet. My request: If there is anything missing, redundant or incorrect in the configurations, can you correct it?
In terms of the first one, that is one approach, and the changes I see are about pppoe connection:
/ip dhcp-client { NOT REQUIRED, you create the ISP termination via pppoe not dhcp client - disable this!! ) add interface=“bridge E1-E2”
add address=10.XX.XX4.0/20 gateway=10.XX.XXX.40 ( If this is your pppoe conectionensure you remove, not required ) add address=192.168.88.0/24 gateway=192.168.88.1
What is not clear to me is the purpose of vlan35 and vlan55.
Assuming vlan35 is internet and vlan55 is TV, they should be associated with interface bridge E1-E2 I would think. /interface vlan
add interface=bridgeE1-E2 name=vlan1 vlan-id=55
add interface=bridgeE1-E2 name=vlan35 vlan-id=35
If vlan35 is your internet then: /interface pppoe-client
add add-default-route=yes disabled=no interface=vlan35 name=
pppoe-out-1 use-peer-dns=yes user=XXXXXXXXXXXXXXXXXXXXXXXXX@ttnet
Missing vlan-filtering=yes on the bridge after you complete BOTH /interface bridge ports and /interface bridge vlans.
add bridge=bridgeE1-E2 tagged=bridgeE1-E2,ether1 vlan-ids=35 { internet comes in on ether1, and is terminated on pppoe } add bridge=bridgeE1-E2 tagged=bridgeE1-E2,ether1,ether2 vlan-ids=55 { tv comes in on ether1, and out to ether2 }
