Please check my FW rules for Unifi controller?
Hi, I have a Unifi controller behind a Mikrotik 3011 that works for my local gear. I want to add another site with APs that are at a friends house. I got the port list from https://help.ubnt.com/hc/en-us/articles/218506997-UniFi-Ports-Used that need to be open.
Can someone confirm my firewall rules are configured correctly? The unifi server is at 192.168.254.12
    "Unifi TCP Ports" connection-nat-state=dstnat \
    connection-state=established,related dst-port=8080,8443,8880,8843,6789 \
    in-interface-list=WAN protocol=tcp
    "Unifi UDP Ports" connection-nat-state=dstnat \
    connection-state=established,related dst-port=3478 in-interface-list=WAN \
    protocol=udp
/ip firewal nat
add action=dst-nat chain=dstnat comment="Unifi TCP Ports" dst-address=\
    x.x.x.x dst-port=8080,8443,8880,8843,6789 in-interface-list=WAN \
    protocol=tcp to-addresses=192.168.254.12
add action=dst-nat chain=dstnat comment="Unifi UDP Ports" dst-address=\
    x.x.x.x dst-port=3478 in-interface-list=WAN protocol=udp \
I believe this to be correct and I see some packets flowing, but the site is offline. I am just trying to narrow down the problem - so if anybody can confirm these are setup correctly I would appreciate it.
You’ve mixed things together in the filter rules.
"action=accept connection-state=established,related"´is used to accept packets belonging or related to already known connections, so in usual cases there should be no additional conditions in this rule. Rules following it are used to enable establishment of new connections. So you should use a separate rule with just “action=accept connection-nat-state=dstnat” to permit any incoming connection previously dst-nated by /ip firewall nat rules. As you’ve combined the conditions which “new” packets must meet in order to be accepted with a condition saying they must not be “new” in a single rule, no “new” packet will ever go through, so no connection will ever be initiated.
Plus whatever you do with the firewall must be done in the context of already existing firewall rules. So post the complete export, not just the part you think may be related. See the mini-howto in my automatic signature.
You are a scholar and a gentlemen. That was the nudge I was looking for. I have that established,related rule above these. As usual, you were spot on.
I unchecked connection state established & related and left the connection-nat=dstnat. The moment I did that it packets matched and it started working.
I have learned a great deal from you on this forum. Your willingness to consistently share your expertise and teach all of us is remarkable. You are an asset to this community and I appreciate your efforts very very much. Good karma to you sir.
Thank you.
