Please check my setting ist fine or wrong?
Hay,
Can you please check my setting if its right or wrong? what i can add or edit to make it better?
[admin@group0] radius> print
Flags: X - disabled
SERVICE CALLED-ID DOMAIN ADDRESS SECRET
0 hotspot 192.168.0.1 123456
1 dhcp 192.168.0.1 123456
[admin@group0] > log
[admin@group0] log> print
14:33:00 web-proxy,warning web proxy cache size is limited by memory size
14:37:51 dhcp,info,debug dhcp1 deassigned 192.168.0.254 from 00:14:85:EF:19:4B
14:37:53 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:37:56 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:38:04 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:38:19 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:38:35 system,info,account user admin logged in via local
14:38:57 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:01 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:04 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:08 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:15 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:31 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:42 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:46 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:39:58 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
14:40:02 dhcp,error,warning,info,debug dhcp1: radius authentication failed for 00:14:85:EF:19:4B: RADIUS server is
not responding
[admin@group0] interface> print
Flags: X - disabled, D - dynamic, R - running
NAME TYPE RX-RATE TX-RATE MTU
0 R leaseline ether 0 0 1500
1 R internal ether 0 0 1500
[admin@group0] interface ethernet> print
NAME MTU MAC-ADDRESS ARP
0 R leaseline 1500 00:0F:EA:4E:0D:12 enabled
1 R internal 1500 00:0E:2E:83:A0:AF enabled
[admin@group0] > snmp
[admin@group0] snmp> print
enabled: no
contact: “”
[admin@group0] user> print
Flags: X - disabled
NAME GROUP ADDRESS
0 ;;; system default user
admin full 0.0.0.0/0
[admin@group0] ip accounting> print
enabled: no
account-local-traffic: no
threshold: 256
[admin@group0] ip service> print
NAME PORT ADDRESS CERTIFICATE
0 telnet 23 0.0.0.0/0
1 ftp 21 0.0.0.0/0
2 www 808 0.0.0.0/0
3 ssh 22 0.0.0.0/0
4 X www-ssl 443 0.0.0.0/0 none
[admin@group0] ip upnp> print
enabled: no
allow-disable-external-interface: yes
show-dummy-rule: yes
[admin@group0] ip socks> print
enabled: no
port: 1080
connection-idle-timeout: 2m
max-connections: 200
[admin@group0] ip dns> print
primary-dns: 212.118.133.102
secondary-dns: 62.149.114.7
allow-remote-requests: yes
cache-size: 2048KiB
cache-max-ttl: 1w
cache-used: 17KiB
[admin@group0] ip address> print
ADDRESS NETWORK BROADCAST INTERFACE
0 ;;; added by setup
192.168.1.115/24 192.168.1.0 192.168.1.255 leaseline
1 ;;; added by setup
192.168.0.1/24 192.168.0.0 192.168.0.255 internal
[admin@group0] ip proxy> print
enabled: no
port: 8080
parent-proxy: 0.0.0.0:1
maximal-client-connecions: 1000
maximal-server-connectons: 1000
[admin@group0] ip pool> print
NAME RANGES
0 dhcp-pool-1 192.168.0.2-192.168.0.254
[admin@group0] ip route> print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf
DST-ADDRESS PREF-SRC G GATEWAY DISTANCE INTERFACE
0 ADC 192.168.0.0/24 192.168.0.1 internal
1 S 192.168.1.0/24 r 192.168.1.1 leaseline
2 ADC 192.168.1.0/24 192.168.1.115 leaseline
3 A S ;;; added by setup
0.0.0.0/0 r 192.168.1.1 leaseline
[admin@group0] ip firewall mangle> print
0 chain=forward src-address=192.168.0.0/24 action=mark-connection new-connection-mark=users-con passthrough=yes
1 chain=forward connection-mark=users-con action=mark-packet new-packet-mark=users passthrough=yes
[admin@group0] ip firewall nat> print
0 chain=srcnat out-interface=leaseline src-address=192.168.0.0/24 action=masquerade
1 chain=dstnat in-interface=internal protocol=tcp dst-port=80 action=redirect to-ports=8080
2 ;;; masquerade hotspot network
chain=srcnat src-address=192.168.0.0/24 action=masquerade
[admin@group0] ip firewall connection> print
Flags: S - seen reply, A - assured
PR.. SRC-ADDRESS DST-ADDRESS TCP-STATE TIMEOUT
0 SA tcp 192.168.0.253:1121 192.168.0.1:8291 established 23h59m59s
[admin@group0] ip firewall> filter
[admin@group0] ip firewall filter> print
0 chain=forward protocol=tcp dst-port=135 action=drop
1 chain=input protocol=tcp dst-port=23 action=drop
2 chain=forward protocol=tcp tcp-flags=syn connection-limit=6,32 action=drop
3 ;;; Drop Invalid connections
chain=input connection-state=invalid action=drop
4 ;;; Allow Established connections
chain=input connection-state=established action=accept
5 ;;; Allow UDP
chain=input protocol=udp action=accept
6 ;;; Allow ICMP
chain=input protocol=icmp action=accept
7 ;;; Allow access to rotr from known network
chain=input src-address=192.168.0.0/24 action=accept
8 ;;; Drop anything else
chain=input action=drop
9 ;;; drop invalid connections
chain=forward protocol=tcp connection-state=invalid action=drop
10 ;;; allow already established connections
chain=forward connection-state=established action=accept
11 ;;; allow related connections
chain=forward connection-state=related action=accept
12 chain=forward src-address=0.0.0.0/8 action=drop
13 chain=forward dst-address=0.0.0.0/8 action=drop
14 chain=forward src-address=127.0.0.0/8 action=drop
15 chain=forward dst-address=127.0.0.0/8 action=drop
16 chain=forward src-address=224.0.0.0/3 action=drop
17 chain=forward dst-address=224.0.0.0/3 action=drop
18 chain=forward protocol=tcp action=jump jump-target=tcp
19 chain=forward protocol=udp action=jump jump-target=udp
20 chain=forward protocol=icmp action=jump jump-target=icmp
21 ;;; deny TFTP
chain=tcp protocol=tcp dst-port=69 action=drop
22 ;;; deny RPC portmapper
chain=tcp protocol=tcp dst-port=111 action=drop
23 ;;; deny RPC portmapper
chain=tcp protocol=tcp dst-port=135 action=drop
24 ;;; deny NBT
chain=tcp protocol=tcp dst-port=137-139 action=drop
25 ;;; deny cifs
chain=tcp protocol=tcp dst-port=445 action=drop
26 ;;; deny NFS
chain=tcp protocol=tcp dst-port=2049 action=drop
27 ;;; deny NetBus
chain=tcp protocol=tcp dst-port=12345-12346 action=drop
28 ;;; deny NetBus
chain=tcp protocol=tcp dst-port=20034 action=drop
29 ;;; deny BackOriffice
chain=tcp protocol=tcp dst-port=3133 action=drop
30 ;;; deny DHCP
chain=tcp protocol=tcp dst-port=67-68 action=drop
31 ;;; deny TFTP
chain=udp protocol=udp dst-port=69 action=drop
32 ;;; deny PRC portmapper
chain=udp protocol=udp dst-port=111 action=drop
33 ;;; deny PRC portmapper
chain=udp protocol=udp dst-port=135 action=drop
34 ;;; deny NBT
chain=udp protocol=udp dst-port=137-139 action=drop
35 ;;; deny NFS
chain=udp protocol=udp dst-port=2049 action=drop
36 ;;; deny BackOriffice
chain=udp protocol=udp dst-port=3133 action=drop
37 ;;; drop invalid connections
chain=icmp protocol=icmp icmp-options=0:0 action=accept
38 ;;; allow established connections
chain=icmp protocol=icmp icmp-options=3:0 action=accept
39 ;;; allow already established connections
chain=icmp protocol=icmp icmp-options=3:1 action=accept
40 ;;; allow source quench
chain=icmp protocol=icmp icmp-options=4:0 action=accept
41 ;;; allow echo request
chain=icmp protocol=icmp icmp-options=8:0 action=accept
42 ;;; allow time exceed
chain=icmp protocol=icmp icmp-options=11:0 action=accept
43 ;;; allow parameter bad
chain=icmp protocol=icmp icmp-options=12:0 action=accept
44 ;;; deny all other types
chain=icmp action=drop
[admin@group0] ip firewall service-port> print
NAME PORTS
0 ftp 21
1 tftp 69
2 irc 6667
3 X h323
4 quake3
5 X gre
6 X pptp
[admin@group0] ip hotspot> print
Flags: X - disabled, I - invalid, S - HTTPS
NAME INTERFACE ADDRESS-POOL PROFILE
0 server1 internal dhcp-pool-1 hsprof1
[admin@group0] ip hotspot service-port> print
Flags: X - disabled
NAME PORTS
0 ftp 21
[admin@group0] ip hotspot host> print
Flags: S - static, H - DHCP, D - dynamic, A - authorized, P - bypassed
MAC-ADDRESS ADDRESS TO-ADDRESS SERVER IDLE-TIMEOUT
0 DA 00:14:85:EF:19:4B 192.168.1.110 192.168.0.253 server1
[admin@group0] ip hotspot profile> print
Flags: * - default
0 * name=“default” hotspot-address=0.0.0.0 dns-name=“” html-directory=hotspot rate-limit=“” http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=cookie,http-chap http-cookie-lifetime=3d split-user-domain=no use-radius=no
1 name=“hsprof1” hotspot-address=0.0.0.0 dns-name=“” html-directory=hotspot rate-limit=“” http-proxy=0.0.0.0:0
smtp-server=0.0.0.0 login-by=http-chap split-user-domain=no use-radius=yes radius-accounting=yes
radius-interim-update=received nas-port-type=wireless-802.11 radius-default-domain=“” radius-location-id=“”
radius-location-name=“”
[admin@group0] ip hotspot active> print
Flags: R - radius, B - blocked
USER ADDRESS UPTIME SESSION-TIME-LEFT IDLE-TIMEOUT
0 admin 192.168.0.253 20m19s
[admin@group0] ip hotspot user> print
SERVER NAME ADDRESS PROFILE UPTIME
0 admin default 4h3m5s
1 fahed default 1m1s
[admin@group0] ip dhcp-client> print
INTERFACE USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS ADDRESS
internal yes searching…
[admin@group0] ip dhcp-server> print
NAME INTERFACE RELAY ADDRESS-POOL LEASE-TIME ADD-ARP
0 dhcp1 internal dhcp-pool-1 3d
[admin@group0] ip web-proxy> print
enabled: yes
src-address: 0.0.0.0
port: 8080
hostname: “proxy”
transparent-proxy: yes
parent-proxy: 0.0.0.0:0
cache-administrator: “webmaster”
max-object-size: 102400KiB
cache-drive: system
max-cache-size: unlimited
max-ram-cache-size: unlimited
status: running
reserved-for-cache: 29707264KiB
reserved-for-ram-cache: 2048KiB
admin@group0] ip web-proxy cache> print
0 ;;; don’t cache dynamic http pages
url=“:cgi-bin \?” action=deny
1 url=“:\.jpg$” action=allow
2 url=“:\.png$” action=allow
3 url=“:\.gif$” action=allow
4 url=“:\.flv$” action=allow
5 url=“:\.swf$” action=allow
6 url=“:\.exe$” action=allow
7 url=“:\.zip$” action=allow
8 url=“:\.3gp$” action=allow
9 url=“:\.mp3$” action=allow
10 ;;; youtube
url=“httpyoutubeget_video*” action=allow
admin@group0] tool user-manager router> print
Flags: X - disabled
0 subscriber=admin name=“group0” ip-address=192.168.0.1 shared-secret=“123456”
[admin@group0] tool user-manager credit> print
SUBSCRIBER NAME TIME FULL-PRICE EXTEND-PRICE
0 admin 1Month 31Days 4w3d 70 unavailable
[admin@group0] tool user-manager user> print
0 subscriber=MikroTik username=“demo” password=“demo” uptime-used=3m59s download-used=593971 upload-used=89604
last-seen=jun/05/2007 14:06:52 credit-count=0 credit-left=0s credit-duration=0s credit-price=0
credit-till-time=jan/01/1970 00:00:00 credit-time-added=0s
1 subscriber=admin username=“1” password=“1” first-name=“1” last-name=“1” uptime-limit=1h uptime-used=1h
download-used=9897174 upload-used=629454 last-seen=jun/05/2007 15:13:29 credit-count=0 credit-left=0s
credit-duration=0s credit-price=0 credit-till-time=jan/01/1970 00:00:00 credit-time-added=0s
[admin@group0] tool user-manager session> print
Flags: A - active
0 subscriber=MikroTik user=“demo” nas-port=2156920837 nas-port-type=wireless-802.11
calling-station-id=“00:14:85:EF:19:4B” acct-session-id=“80900005” user-ip=192.168.0.254 host-ip=192.168.0.1
status=start,stop from-time=jun/05/2007 14:02:54 till-time=jun/05/2007 14:06:52 terminate-cause=lost-carrier
uptime=3m59s download=593971 upload=89604
1 subscriber=admin user=“1” nas-port=2156920840 nas-port-type=wireless-802.11 nas-port-id=“internal”
calling-station-id=“00:14:85:EF:19:4B” acct-session-id=“80900008” user-ip=192.168.0.254 host-ip=192.168.0.1
status=start,stop,interim from-time=jun/05/2007 14:13:29 till-time=jun/05/2007 15:13:29
terminate-cause=session-timeout uptime=1h download=9897174 upload=629454
[admin@group0] tool user-manager customer> print
Flags: X - disabled
0 subscriber=admin login=“admin” password=“” date-format=“%m/%d/%y” time-zone=+03:00 permissions=owner parent=admin
1 subscriber=MikroTik login=“MikroTik” password=“qwerty” time-zone=+00:00 permissions=owner parent=MikroTik
[admin@group0] tool sniffer> print
interface: all
only-headers: no
memory-limit: 10
file-name: “”
file-limit: 10
streaming-enabled: no
streaming-server: 0.0.0.0
filter-stream: yes
filter-protocol: ip-only
filter-address1: 0.0.0.0/0:0-65535
filter-address2: 0.0.0.0/0:0-65535
running: no
Hope any one check my setting and give me his advice
what is exactly your problem? only get better configuration?
Fran.
I want your idea .IS my setting best configuration or i need to adjust it?
Thanks Again
nice config… I think he just wants suggestions and improvements..
Fahedksa,
What are you using for radius authentication? Are you using freeradius or MT? If can also post your radius export too so we can see those settings…
Matt
