I’m experiencing some issues with my home setup which is mainly intermittent episodes of high latency and then minimal latency, but also my laptop not receiving an IP address from the bridged network. My setup is basically a RB2011UiAS-2HnD-IN powering a SXT Lite5 from the PoE port. There’s another SXT Lite5 300m away hooked up to a generic router.
ping 8.8.8.8 -I wlp3s0 -dv
From 192.168.88.X: icmp_seq=2 Redirect Host(New nexthop: 192.168.0.1)
From 192.168.88.X: icmp_seq=3 Redirect Host(New nexthop: 192.168.0.1)
From 192.168.88.X icmp_seq=2 Destination Host Unreachable
From 192.168.88.X icmp_seq=3 Destination Host Unreachable
From 192.168.88.X: icmp_seq=4 Redirect Host(New nexthop: 192.168.0.1)
(Note: this is not a paste from the terminal; I’m using my memory hence the “X”)
I have also seen this:
64 bytes from 8.8.8.8: icmp_seq=454 ttl=60 time=208 ms
64 bytes from 8.8.8.8: icmp_seq=456 ttl=60 time=147 ms
Warning: time of day goes back (-72508us), taking countermeasures.
Warning: time of day goes back (-72438us), taking countermeasures.
64 bytes from 8.8.8.8: icmp_seq=457 ttl=60 time=0.000 ms
64 bytes from 8.8.8.8: icmp_seq=459 ttl=60 time=558 ms
64 bytes from 8.8.8.8: icmp_seq=460 ttl=60 time=184 ms
Here’s the configuration of the RB2011:
# oct/19/2016 12:37:41 by RouterOS 6.28
# software id = 2U21-M0L9
add admin-mac=4C:5E:0C:XX:XX:XX auto-mac=no name=bridge-local
set [ find default-name=ether1 ] name=ether1-gateway
set [ find default-name=ether2 ] name=ether2-master-local
set [ find default-name=ether3 ] master-port=ether2-master-local name=\
ether3-slave-local
set [ find default-name=ether4 ] master-port=ether2-master-local name=\
ether4-slave-local
set [ find default-name=ether5 ] master-port=ether2-master-local name=\
ether5-slave-local
set [ find default-name=ether6 ] name=ether6-master-local
set [ find default-name=ether7 ] master-port=ether6-master-local name=\
ether7-slave-local
set [ find default-name=ether8 ] master-port=ether6-master-local name=\
ether8-slave-local
set [ find default-name=ether9 ] master-port=ether6-master-local name=\
ether9-slave-local
set [ find default-name=ether10 ] master-port=ether6-master-local name=\
ether10-slave-local
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=11 band=2ghz-b/g/n country=\
"united kingdom" disabled=no distance=indoors frequency=auto \
frequency-mode=regulatory-domain l2mtu=2290 mode=ap-bridge ssid=XXXYYY \
wireless-protocol=802.11
/ip neighbor discovery
set ether1-gateway discover=no
set [ find default=yes ] authentication-types=wpa2-psk mode=dynamic-keys
add name=dhcp ranges=192.168.88.10-192.168.88.254
add name=wifi ranges=192.168.87.10-192.168.87.254
add name=mgmt ranges=192.168.0.2-192.168.0.254
add address-pool=dhcp disabled=no interface=bridge-local name=default
add address-pool=mgmt disabled=no interface=ether1-gateway name=mgmt
/port
set 0 name=serial0
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add bridge=bridge-local interface=ether2-master-local
add bridge=bridge-local interface=ether6-master-local
add bridge=bridge-local interface=sfp1
add bridge=bridge-local interface=wlan1
add address=192.168.88.1/24 comment="default configuration" interface=\
bridge-local network=192.168.88.0
add address=192.168.87.1/32 disabled=yes interface=ether2-master-local \
network=255.255.255.0
add address=192.168.1.2/32 interface=ether1-gateway network=255.255.255.0
/ip dhcp-client
add comment="default configuration" dhcp-options=hostname,clientid interface=\
ether1-gateway
add default-route-distance=0 dhcp-options=hostname,clientid disabled=no \
interface=ether10-slave-local
add address=192.168.1.0/24 gateway=192.168.1.1
add address=192.168.88.0/24 comment="default configuration" gateway=\
192.168.88.1
set allow-remote-requests=yes servers=8.8.8.8
/ip dns static
add address=192.168.87.1 name=router
add chain=input comment="default configuration" disabled=yes protocol=icmp
add chain=input comment="default configuration" connection-state=\
established,related disabled=yes
add action=drop chain=input comment="default configuration" disabled=yes \
in-interface=ether1-gateway
add chain=forward comment="default configuration" connection-state=\
add action=drop chain=forward comment="default configuration" \
connection-state=invalid disabled=yes
connection-nat-state=!dstnat connection-state=new disabled=yes \
add chain=output disabled=yes
add action=masquerade chain=srcnat comment="default configuration" \
out-interface=ether1-gateway
/romon port
add disabled=no
/system clock
set time-zone-name=Europe/London
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set bridge-local disabled=yes display-time=5s
set wlan1 disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
set ether1-gateway disabled=yes display-time=5s
set ether2-master-local disabled=yes display-time=5s
set ether3-slave-local disabled=yes display-time=5s
set ether4-slave-local disabled=yes display-time=5s
set ether5-slave-local disabled=yes display-time=5s
set ether6-master-local disabled=yes display-time=5s
set ether7-slave-local disabled=yes display-time=5s
set ether8-slave-local disabled=yes display-time=5s
set ether9-slave-local disabled=yes display-time=5s
set ether10-slave-local disabled=yes display-time=5s
/system ntp client
set enabled=yes primary-ntp=109.74.206.120 secondary-ntp=85.119.80.232
/tool mac-server
add interface=ether2-master-local
add interface=ether3-slave-local
add interface=ether4-slave-local
add interface=ether5-slave-local
add interface=ether6-master-local
add interface=ether7-slave-local
add interface=ether8-slave-local
add interface=ether9-slave-local
add interface=ether10-slave-local
add interface=sfp1
add interface=wlan1
add interface=bridge-local
/tool mac-server mac-winbox
add interface=sfp1
add interface=wlan1
/tool user-manager database
set db-path=user-manager
Can anyone diagnose the problem?
