Please delete this topice.
Wouldn't some simple action=dst-nat chain=output NAT rule do what you need for the client part? and for the server part, action=dst-nat chain=dstnat rules?
If there are only a few L2TP clients, we can change the port using DNAT.
But,
what if there are 500 L2TP clients?
What if there are 1,000 L2TP clients?
and using 500+ 1000+ dst-nat rules?
And, what is the difference? If you have 1000 L2TP clients, you already have 1000 entries under PPP -> Interfaces to manage.
And for the L2TP server, you can even have one single DSTNAT action=dst-nat chain=dstnat dst-port=10000-20000 to-ports=1701 rule for your 10000 of choosable ports.
IPLC/IPEL Server
200.200.200.200
200.200.200.200:10001-10010 --> l2tp-server public ip 1 ( 10001-10010 redirect 1701 )
200.200.200.200:10011-10020 --> l2tp-server public ip 2 ( 10011-10020 redirect 1701 )
200.200.200.200:10021-10030 --> l2tp-server public ip 3 ( 10021-10030 redirect 1701 )
200.200.200.200:19991-20000 --> l2tp-server public ip 999 ( 19991-20000 redirect 1701 )
Now all I need to do is add the L2TP custom port option.
Managing and maintaining such a large L2TP client using dst-nat rules is really terrible.
I know that dst-nat can change ports; the topic of this post is requesting the addition of this feature.
/ip firewall nat add action=dst-nat chain=output dst-port=1701 protocol=udp to-ports=10001
Write this request directly to MT support, there are low chances that it will be noticed here on the forum.
