Please fix the "Default" Agent issue
Age=Default>>>> Delaaaaaaay
Using the dude Client
I have seen this in both current release 6.38.5 and the RC 6.39.55
When the Agent is set to default, opening any device settings would take too much, but if the Agent is set to “server” problem is fixed.
things I have tried:
Rescan the devices while setting Agent=server (returns to default after a while)
Modifying the device settings to use the server agent instead of default.(returns to default after a while)
Selecting all devices in the map and set the agent for all of them to server (returns to default after a while)
I have made sure there are any agents defined in the agents section.
I have only one dude server.
I strongly believe this is a bug, please fix it.
