i have an internet connection and a community network connection at my home. internet connection is masquerade but the other connection is not masquerade, it is simply routed. now i use two router one for internet connection and another for that community network. i just got an RB750GL and want to replace that two old router. how it is possible? i do not want to share my internet over that community network.
this is my current setup:
both are TP-Link wr740n v4.23 router with OpenWRT 12.09 and wi-fi is switched off. I only use them for routing purpose. I have other gears for wireless set up.
my home network is 172.18.3.0/27
router A WAN port have a single IP of network A which have internet and it is masquerade. gateway provided by my ISP
router A LAN port have 172.18.3.1/27
router A have a static route at LAN side for network 172.18.0.0/16, gateway is the router B LAN IP
router B WAN port have a single IP of network B which don’t have internet access and not masquerade. there is no gateway
router B LAN port have 172.18.3.30/27
router B have a static route at WAN side for network 172.18.0.0/16, gateway is the next router of network B
efaden, that community network don’t have internet but have some ftp server, some game server and a VoIP server. In my country hi speed internet is costly so I and couple of my friends build that network which is runs over point to point WiFi link.
can you elaborate me firewall rules for my setup??
Basically make your masq rule only masq traffic out the WAN and coming from your own internal network… Other than that just allow or block whatever you want. If you get stuck post your config and what isn’t working.
