Please help, cannot get dual WAN (dhcp client) working properly
Hi all,
I’ve searched and found a few posts on here and followed suggestions (I’ll list what I’ve tried below) but I cannot for the life of me get dual WAN working as I want.
I have 2 WAN devices, one is a mikrotik SXT in LTE Passthrough mode (eth1-LTE) and then a starlink in bypass mode (eth5-STARLINK). Now they both give an ip address correctly to the dhcp_client on my hAP ax^3.
From winbox, I can ping and tracert, specifying either interface and I can see the response I expect, each interface works fine, great.
However, when I try to mark a specific mac address on my lan to use a specific connection, I cannot get it to work, it gets no traffic at all (in the example it’s the device commented “[STARLINK-MARK] S24”. If I look in connections list I can see the traffic has the right connection mark and in my mangle I set routing mark based on connection mark.
But no connections get established in that instance.
What I’ve tried?
Changed dhcp_client to add default route yes/no
Setup a script (you’ll see in config) to change gw when dhcp_client gets an address
Tried to set gw in the route to include interface (i.e 10.30.11.23%eth5-STARLINK)
Changed priority of route (when default route added) to be higher than the static I’ve added.
In the example script below, all traffic is now going through the LTE interface fine, but I can’t get it to send anything over the starlink one, unless I disable the eth1-LTE interface completely and all references and then it works on STARLINK).
Please can someone have a look and let me know what I’m doing wrong?
Thank you
add admin-mac=DXXXXXXXXXXXX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] comment="[LTE PoE]" name=eth1-LTE
set [ find default-name=ether2 ] comment="[LAN]" name=eth2-LAN
set [ find default-name=ether4 ] comment="[SXT Mgmt]" name=eth4-SXT
set [ find default-name=ether5 ] comment="[STARLINK]" name=eth5-STARLINK
set [ find default-name=ether3 ] disabled=yes
/interface wifi
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz comment="2Ghz WIfi" configuration.mode=ap \
.ssid="Mikro Space Princess" disabled=no name=wifi2Ghz \
security.authentication-types=wpa2-psk,wpa3-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz comment="5Ghz Wifi" configuration.mode=ap \
.ssid="Mikro Space Princess" disabled=no name=wifi5Ghz \
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifi configuration
add datapath.client-isolation=yes disabled=no name=guestWifiCfg \
security.authentication-types=wpa2-psk ssid="Guest Space Princess"
/interface wifi
add comment="[Guest Wifi 2Ghz]" configuration=guestWifiCfg \
configuration.mode=ap disabled=no mac-address=Dxxxxxxxxxxxxx\
master-interface=wifi2Ghz name=guest2Ghz
add name=dhcp_pool1 ranges=192.168.74.100-192.168.74.200
add name=guest_pool ranges=192.168.75.100-192.168.75.125
add name=pool2 ranges=192.168.99.2-192.168.99.254
add address-pool=dhcp_pool1 comment="[Bridge DHCP]" interface=bridge \
lease-time=10m name=dhcpBridge
add address-pool=pool2 interface=guest2Ghz name=dhcp2
/routing table
add disabled=no fib name=ROUTE_STAR
add disabled=no fib name=ROUTE_LTE
add bridge=bridge comment=defconf interface=eth2-LAN
add bridge=bridge comment=defconf interface=eth4-SXT
add bridge=bridge comment=defconf interface=wifi5Ghz
add bridge=bridge comment=defconf interface=wifi2Ghz
add comment=defconf interface=eth1-LTE list=WAN
add interface=eth5-STARLINK list=WAN
add address=192.168.74.1/24 comment=defconf interface=bridge network=\
192.168.74.0
add address=192.168.99.1/24 interface=guest2Ghz network=192.168.99.0
/ip dhcp-client
add add-default-route=no comment=STARLINK interface=eth5-STARLINK script=":if \
(\$bound=1) do={\
\n:local gw \$\"gateway-address\"\
\n/ip route set [ find comment=\"[STARLINK]\" gateway!=\$gw ] gateway=\$gw\
\n}" use-peer-dns=no
add address=192.168.74.0/24 comment=defconf dns-server=1.1.1.1,1.0.0.1 \
gateway=192.168.74.1
add address=192.168.99.0/24 dns-server=1.1.1.1 gateway=192.168.99.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
/ip firewall address-list
add address=192.168.74.100-192.168.74.200 comment="[DHCP]" list=DHCP
add address=192.168.99.2-192.168.99.254 list="Guest WiFi"
established,related,untracked
add action=accept chain=forward comment="[FWD] Nautilus" \
src-mac-address=XXXXXXXXXXXX
add action=accept chain=forward comment="[FWD] Laptop" src-mac-address=\
3XXXXXXXXXXXX
add action=accept chain=forward comment="[FWD] Macbook" src-mac-address=\
XXXXXXXXXXXX
add action=accept chain=forward comment="[OUT] LAN->WAN" in-interface-list=\
LAN out-interface-list=WAN
add action=accept chain=forward comment="[FWD] bridge -> WAN" disabled=yes \
in-interface=bridge out-interface-list=WAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
disabled=yes in-interface-list=!LAN
invalid disabled=yes
add action=drop chain=forward comment="[DROP] LTE->STARLINK" disabled=yes \
in-interface=eth1-LTE out-interface=eth5-STARLINK
add action=drop chain=forward comment="[DROP] STARLINK->LTE" disabled=yes \
in-interface=eth5-STARLINK out-interface=eth1-LTE
add action=log chain=forward comment="[LOG] Everything else" disabled=yes \
log-prefix=DROPPED
connection-state=invalid
add action=drop chain=input dst-address=192.168.99.1
add action=drop chain=forward dst-address=192.168.88.0/24 src-address-list=\
"Guest WiFi"
add action=drop chain=forward out-interface-list=!WAN src-address=\
192.168.99.0/24
/ip firewall mangle
add action=mark-connection chain=prerouting comment="[LTE-MARK] DHCP Traffic" \
new-connection-mark=CONN_LTE passthrough=yes src-address-list=DHCP
add action=mark-connection chain=prerouting comment="[STARLINK-MARK] S24" \
new-connection-mark=CONN_STAR passthrough=yes src-mac-address=\
xxxxxxxxxxxxx
add action=mark-routing chain=prerouting comment="[MARK-ROUTE] STARLINK" \
connection-mark=CONN_STAR new-routing-mark=ROUTE_STAR passthrough=no
add action=mark-routing chain=prerouting comment="[MARK-ROUTE] LTE" \
connection-mark=CONN_LTE new-routing-mark=ROUTE_LTE passthrough=no
connection-mark=CONN_LTE ipsec-policy=out,none out-interface=eth1-LTE
connection-mark=CONN_STAR ipsec-policy=out,none out-interface=\
eth5-STARLINK
/ip firewall service-port
set ftp disabled=yes
set sip disabled=yes
/ip ipsec profile
add comment="[STARLINK]" disabled=no distance=10 dst-address=0.0.0.0/0 \
gateway=X.X.X.X%eth5-STARLINK routing-table=ROUTE_STAR scope=30 \
suppress-hw-offload=no target-scope=10
add comment="[LTE]" disabled=yes distance=10 dst-address=0.0.0.0/0 gateway=\
eth1-LTE routing-table=ROUTE_LTE scope=30 suppress-hw-offload=no \
target-scope=10
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" \
dst-port=33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Europe/London
/system note
set show-at-login=no
/tool bandwidth-server
set enabled=no
/tool mac-server
/tool mac-server mac-winbox
https://help.mikrotik.com/docs/spaces/ROS/pages/59965508/Policy+Routing
