Please help in connecting sxt-5d
Greetings
I do not know how to contact the local networks and I am a new user in Iraq, no one knew how to contact possible way wireless connectivity and the picture will be Baltvsbl
Thank you in advance
connect where ?
tell us more about your equipment, and desired setup
I have SXT 5HnD been linked to the device successfully introduced Ip 192.168.88.1 but I do not know how to reach us through the program winbox
Note of the communication network used by Broadband Connection
you didn’t answer my question.
what equipment do you have, and what do you want to configure. make a network layout drawing please.
I have
1- SXT 5HnD
2- Laptop Computers
I want to contact provider Internet service
I do not know how to reach us by winbox
I use before NanoStation5
((I replaced NanoStation5 in SXT 5HnD and I want him to do the same NanoStation5))
I’m sorry I’m not good in English
This Video to clarify my request
http://www.youtube.com/watch?v=k6GULV-xtLM
Move the SXT box away from the antenna!! If you place it behind the other antenna you may have some interference and it’s blocking your signal on the SXT! Place it above the other antenna (about 50cm or so) to get better signal and to counter interference.
sorry
up
I looked at your video, several problems:
  1. where is the cover? you should put it back, and close it, so that no dust can get inside
  2. The SXT is mounted incorrectly, the correct mounting direction is like this:
  1. The SXT is blocked by that other antenna! You didn’t attach the SXT to the pole, you have squeezed it into a gap between one antenna and the pole, 1/4 of the antenna surface is blocked by that panel antenna. Here are some images how to mount it correctly: http://forum.mikrotik.com/t/sxt-testing-results/44156/1
Ok Thank you all been linked to the network successfully, but there is something I do not know
Network uses PPPoE I try to connect but failed
Possible way
I’m sorry to the many questions
I was contacted by ((Broadband Connection))
Now, how is the internet connection by the winbox
I make pppoe-out1 in winbox and Works successfully connect but no internet
Possible of the correct way so that I can connect to internet
I’m tired of this problem
Have you tried to enable DHCP-Client on that interface? If you have not, you will not have any IP to access the internet.
how enable DHCP-Client
Worked as in the picture but did not work Internet
I have numbers, the process of preparing Khaled
Is this true and please provide me the right way Sign
Do I have to work more
I want to receive the Internet in a computer I do not want any other customs
Did not get the Internet
Please correct way
you still need masquerade rule
http://wiki.mikrotik.com/wiki/Manual:RouterOS_FAQ#TCP.2FIP_Related_Questions
[admin@MikroTik] ip firewall nat> add chain=srcnat action=masquerade out-interface=Public
I do not know how I thank you, esteemed
Possible tell me how do I implement this
First, enter these things in a new NAT rule:
then, set action “masquerade” in the same rule “action” tab
“out interface” should be the name of the interface where the internet is
I did as you told me but did not show -out interface- interface
There is no Internet
what did you put into the “out interface” field?
if internet on the Ethernet side, or on the other end of the wireless link?
this on out interface
