I bought a Audience online, they sent me a Audience LTE instead (their mistake)
I was able to use Winbow to get it to act as a non-lte and pass thru internet, But I want it to be in Bridge mode so my primary router does all the routing.
Current setup is a (primary) CRS125-24G-1S-2HnD
And a (secondary) RB2011UiAS-2HnD
ISP router is only used to feed Primary.
Secondary is fed by Primary
Primary is set as Home AP mode, Secondary as PTP Bridge AP
Primary is DHCP server.
Both have wifi enabled (with different SSID’s)
My plan is to use the Audience as the only wifi (using both 2.4 and 5 GHz)
Plan in to disable wifi on Primary and Secondary.
The Audience did not have a quickset option in Winbox to enable bridge mode with dual wifi.
I saw another post mention this and a reply said quickset are only simple presets, with the right config any option is possible.
I’m hoping someone can guide me.
I have used winbox some, but usually only the more common stuff.
I havent used scripting or cli.(?) or console.
I tried to include any details i think you may need, sorry if i missed anything.
