please help me in designing my network in well and good
Hi all,
Can anyone help me in designing my new network with following resources.
1.Got 2MBps leased line from ISP
2.have level 6 MikroTik OS installed
3.got to manage 150 Nodes in the network.
4.got static ip’s around 30 from ISP.
5.have DAX 1821 router
So kindly advice or recommend me how good and well i should configure or set my network to trouble less and simply manageable.
Thanks a lot in advance.
you can contact our certified consultants to do this:
http://www.mikrotik.com/consultants.html
Yep, there are QUITE a few more pieces of information that would be needed to manage a network like that. http://www.mikrotik.com/consultants.html is the place to go!
Hmm it sounds great for implementing network from zero.
I can help you by contacting me to my YM aagyung or email at agungikhtiarcomputercocc
Ur friend from Indonesia
-Yusuf-
i can still be happy if someone could explain overall design in a simple form…
Thanks a lot.
Ram.
