I upgraded to 5.9 still having problems with the wireless radios not working, while Activation of wireless radio RouterBoard, The flaw is Work restart every 5 minutes Or less than this time, See the pictures for some of the mistakes that occur, Please Please Please help me
btw, it’s 5.0RC1, not even 5.0 final - try to install the latest version
to downgrade, upload v4.17 files and go to System → Packages → Downgrade
I thank you for the reply
I could not return the update version By this method to downgrade, (upload v4.17 files and go to System → Packages → Downgrade) .
Please help me so I can update this version v4.17 And if possible a Illustration of pictures.
Note: Is there another way, return the update version v4.17 .
THANKS,
why? ![]()
see Log to know the reason
Hi
I thank you for the help, We have solved the problem .
THANKS,
you are welcome =)
p.s. and what was the solution?
you are welcome =)
The solution is Update method through the program (FileZilla 3.2.3 win32.zip) type of the types of programs (FTP).
On a technical level, the issue was probably related to you incorrectly uploading the files in ASCII instead of BINARY format. An intelligent program like FileZilla will detect the type of files you’re uploading and use the proper transfer method.
