Please Help me With CCR Ports
Hello , Please help me ..
i have CCR which has 12Ethernet ports. Ether1 to Ether5 is using 5WAN loadbalancing and Ether6 is LAN using hotspot
Ether1 to Ether5 is dynamic IP address assign from PPPOE server
Ether6 IP Address = 172.16.1.1/16 , DHCP enable = 172.16.2.1- 172.16.254.254
And now i want to use Dmasoftlab radius server for hotspot database…
So. ether6 = 192.168.22.1/24 and Radius Server IP = 192.168.22.2/24
From Mikrotik , i can ping all Radius Server IP,
From LAN client , i can`t ping to my Radius Server…
how can i setup this configuration…
Thanks … Please help me..
What is the problem? What do you want to set up? If you want to set up mikrotik to use radius, just create radius in mikrotik with radius ip and secret. Is documented in DMA documents.
Yes, From DMA Softlab Documentation…just only for one step
Internet ------------------- Switch---------------------------- Mikrotik ---------------------------------hotspot
-----------------------------Radius
For me ,
Internet (5 WAN loadbalancing with PPPOE Client ) ether 1 to 5--------------------------- Mikrotik Ether6 for LAN---------------------------hotspot
--------------------------- Ether7 for Radius
Perhaps i miss interpret, but no different setup for 1 wan or for 5 wan. Authentication happens in hotspot, connecting to radius. Does not matter how many internet connections.
