CPU temperature of windows XP or windows 2000 and windows 2003 is monotoring?
You want to monitor CPU temperature? You just want to graph it?
yes i’am want graph the CPU temperature…
- Ensure you have SNMP enabled on your PC
- Perform and snmpwalk on the PC and look to see if you can find the temp OID (right click->tools->snmpwalk Then click on tree view
- Create a data source for that OID
- SNMP enabled on My PC.
- right click->tools->snmpwalk Then click on tree view
→ i am not found, temp OID.
CPU temperature is not something that is exposed through the standard MS SNMP agent. There is no standard way of reading the temperature, it’s different on every motherboard. Therefor, it’s not something the OS can provide.
You can load extensions to the SNMP agent that makes more values available, some free, some not. For example see here: http://www.wtcs.org/informant/products.htm . There you can find the free ‘SNMP Informant - MBM Agent’ that makes the values MBM collects (MotherBoard Monitor, yet another free tool) available through SNMP. Including CPU temperature.
