I have mikrotik 4.6 on x86 platform. on supermicro mainboard and 2x inel dual core 2 duo procesor.
I have problem with utorrent i cannot block them. i alredy have set chain=forward p2p=allp2p action drop but not working for utorrent it keep running downloading like crazy. bittorrent ktorrent block fine.
I setup L7 filter for bitttorrent, edonky, kazza… and in filter i set chain=forward Layer/ protocol=bittorrent action=drop but i cannot find utorrent l7 header. I setup a webproxy with cache on disk and i have block a torrent pages and utorrent web page
Can you mikrotik experts PLEASE help me to setup l7 header for utorrent or block utorrent on different way???
There is no true-fire way to block torrent, search the forums and you will understand what I mean. I admit this is both good and bad, in that torrent has it’s advanages in lowering server load from the main host, but kills an ISP bandwidth.
I dont know your needs/config but you could try also blocking any unnecessary ports (IE leave only HTTP, DNS or such). I don’t know if this works though, I think I read somewhere here torrent might just start using ANY open ports if it can’t find any good ones.
