Please help with 2 VPLS!!
Hello Mikrotik guys!
I need some help with configuration 2 VPLS (each VPLS for wlans..)
I have 2 wlans (wlan1, wlan2) and I want to create 2 VPLS but only one VPLS is running..
I read in other post: http://forum.mikrotik.com/t/2x-parallel-vpls-tunnel-in-the-same-time/36306/1
“config set only lsr-id , dont set transport-address”
But this one not work in my configuration.
I’m using 4.11.
Please help me!
Hi Dude..
you may can refer to http://forum.mikrotik.com/t/mpls-configuration-for-nv2-routeros-v5-0beta6/39935/1
but this is for the RouterOS 5.6Beta6.
you need to change the value of the “band” and delete “/interface wireless set wlan1 nv2-qos=default”, the rest remain the same..
It’s work in the 4.11, but remember that, have to use mac telnet to the equipment.
forgive me lazy to edit it…
p/s: This is for only 1 wlan card.
Thanks angboontiong!
But I need with 2 wlans..
wlan1 (VPLS1)<-----> (VPLS1) wlan1
wlan2 (VPLS2)<-----> (VPLS2) wlan2
