Please Help with MK3 firewall
Dear Sir’s
I was unsing MK2.9 firewall with no problems, as follows
  1. main rule with address range 172.30.4.20-172.30.4.80
  2. rule for redirect port 80 on wan interfaceto port 8080
  3. rule for redirect port 80 to port 8080 with out choose any interface
this is work very good in the given range.
But I try the same rules with MK3 and browsing fail, And I notice that
If I cancel the range from main rule it work.
I have to use a range to deliver internet for specific users only
Please help
Eng. Amgad
Do you have the proxy service enabled and running on port 8080?
-Louis
yes It is enabled and running.
as when I block sites or download with web-proxy it work.
But this happen it I cancel the range.
I do it in another way I leave the firewall rules without range,
and I add the required range in web-proxy rules and It work for me.
Thanks for your response.
Eng.
Amgad steen
