please help with my upload
i have problem with my connetions
i have connection with ADSL … i set ether1 192.168.1.x and ether2 192.168.0.x .. My LAN .. 192.168.0.x-x , gateway and DNS follow with mikrotik.. my problem : if i upload file ping is Request Time Out … please help me ::slight_smile:
If you haven’t setup masquerading on the MT Router, you need to add a static route to your ADSL router to tell it where to find the 192.168.0.x network.
I’m assuming that the 192.168.1.x network is connected to the ADSL router, if 192.168.0.x network is connected to the ADSL router then you need to add a static router to the ADSL router to tell it where to find the 192.168.1.x network.
Regards
Chris Macneill
