Hello. I'm having trouble mounting the config file in the image due to the switch to mount lists in RouterOS 7.21.3.
/container/set mounts=config.json numbers=0 returns an error on the = sign in mounts=config.json, and the command /container/set mountlists=config.json numbers=0 returns the error "failure: cannot change root-dir"
I couldn't find any solutions online.
Thanks in advance
