my hap lite v6.30.4 have a connection on main(WAN) but on lan no internet please help.
Here you go man, just follow the article and set up your device.
We are suggesting you to simply use a default configuration with your configured strong password:
/system reset-configuration
Be sure you update the device afterwards:
/system package update check-for-updates
/system package update install
