Please Help.......!
Hello Mates,
i want to create a wireless network,already running a wired network.
But don’t have any experience to make or run wireless network, Please somebody help me to make my network?
I need assistance to purchase all equipments and make all settings.
Please Help Me i will be very Thankful to You.
Seems help is scares here. Go to your local electronics dealer and purchase any wireless b/g access point or router. Unpack the unit, plug it in to your wired network and done.
If you include some details about your network i can help you further.
Thanks for your time Buddy.
I don’t have any idea that which kind of equipments will require to create a wireless network.
Plz tell me about the equipments.
hey hello,
if you want information about wireless system contact us.
email is: {email removed}..
It is impossible to tell you about ‘the equipments’ their are thousands of configurations. You must tell us what your goal is.
Example:
Connect 2 computers to the wired network.
The 2 computers are located 5m from each other on the same level of the building.
The 2 computers will only need a 1MB link between them to use the 1MB internet connection.
Any one please help me to start my wireless network?
Any suggestions for hardware required?
How do you expect help without any information about your goal?
i have 40+ clients on my wired network.
i want to expend my setup to other areas,so please suggest me equipments for it?
i want to cover 2Km area 360 degree. means 2Km in every side or minimum 1km.
i want to connect more then 100 computers located different places in different buildings through wireless connectivity.
All 100 pcs will be connected via wireless ? Or only 1, or it is wireless backbone? What distance between the locations?
no some computers will connect through wire and most will b via wireless.
as i said b4 that i am running a small network in my area (Internet Service Provider).
now i want to start my wireless network.
and here i want to get suggestions to purchase equipments for my network.
Sorry TSTH. Good Luck
