i have a RB951Ui-2HnD router, it was working fine but then i don’t know what happened and now i cant log in when i but the 192.168.88.1 in the browser, also the network is shown Unidentified (Limited), i have tried resetting the router and changing the Ethernet cable but I still cant log in to configure it.
thank you
Usually the first thing i try is a hard factory reset of the device.
Follow these instructions
http://i.mt.lv/routerboard/files/rb951Ui-2HnD-qg-140219101058.pdf
If that doesnt work i re load the operating system.
http://www.mikrotik.com/testdocs/ros/2.9/guide/netinstall.php
Good luck!
Is your problem solved?
