hello
can i use r52n or r52hn with one antenna ?
and if yes will the n mode will work ?
and what the speed will got ?
Just read specifications www.routerboard.com/pdf/R52n.pdf
Or more descriptive specification of simillar product http://www.unex.com.tw/sites/default/files/pdf/DNMA-92%20datasheet.pdf
Hi, I use r52n with one chain some time ago when I got water in other chain cable at AP side. Stable 117Mbps-HT connection in both way with ~ 50mbit half duplex real true output.
ok buy how i can disable the secend port
Just run a single chain.
Tom
thanks for all
