Please need help about CCR1009-8G-1S-1S+
Hello everybody,
I am interested to buy an CCR1009-8G-1S-1S+ router.
Can you tell me if this router supports dual Wan fail-over ?
I have 2 different ISP-s . One fixed cable connection and the second is a VDSL Modem connection .
Can I use the VDSL connection as backup if the primary one fails?
Also this router is good for 50 users?
Thank you in advance.
Luis
Yes to all questions.
Maybe you can utilise cheaper device depending on the throughput (and pps) that you have not noticed.
