You really are going to have to put a little more effort in describing your problem.
This is like saying ; When I’m in my car I hear a sort of humming, how come ?
I am not sure what the issue, is?
I have the plex and emby apps on my apptetv and they work fine.
I am using servers on the internet by the way. No special settings.
Plex is on a docker as host, with port forwarding set up to the server, It plays perfectly away from home.
When I try and use plex app on my my iPhone and appletv I get limited connection and nothing plays.
I have read that it could be dnsmasq but I have no idea what that is or how to change it, looking for some help
The network diagram will fully explain the connectivity between component of the network and if annotated with Ip addresses will explain the subnet relationships.
The config is something you can create from the terminal part of winbox,
It then puts the file into the FILES selection in winbox and then you can download it, open it with notepad++
then paste in here.
Just be sure to use the CODE tags on the same line above as B and Underline (its the black square with white square brackets)/
I think it’s dns rebinding that is the problem as it’s the same as unRAID.net
How do I add plex.direct and unraid.net to my router so I can access them using the domain name and not my ipaddress ie UnRAID.net and app.plex.tv
Plex app on your phone ? And your are connected on WIFI on your LOCAL LAN ? What is the purpose of the iphone ? If the Plexapp is on AppleTV, and AppleTV connected to a TV-set, why not control the Plex-app on AppleTV with the remote while you are at home ?
Anyway, it might be related to “hairpin nat” ? On your iPhone / Plex-app, what “server” information is filled in ? Your public IP ? Some DNS-name ?
You probably try to call the same hostname (eg. plexserver.mydomain.something) from inside your home local network ??
Appletv has its own app and so does iPhone when you connect you join to app.plex.tv not your local server if I could just put in the ipaddress it would be easier for me I dont have a domain setup on it I could I have a domain for other things but not plex
