Pls Help Me
hi i have a routerboard 1000 and i work with pppoe and i would like to make 2 or 3 profiles for my client for ex some clients i would like to give 512 kb some others 768 kb how can i change the speed?pls help me…
http://wiki.mikrotik.com/wiki/PPP_AAA#User_Profiles
User Profiles
Sub-menu: /ppp profile
PPP profiles are used to define default values for user access records stored under /ppp secret submenu. Settings in /ppp secret User Database override corresponding /ppp profile settings except that single IP addresses always take precedence over IP pools when specified as local-address or remote-address parameters.
rate-limit (string; Default: )
Rate limitation in form of rx-rate[/tx-rate] [rx-burst-rate[/tx-burst-rate] [rx-burst-threshold[/tx-burst-threshold] [rx-burst-time[/tx-burst-time] [priority] [rx-rate-min[/tx-rate-min]]]] from the point of view of the router (so “rx” is client upload, and “tx” is client download). All rates are measured in bits per second, unless followed by optional ‘k’ suffix (kilobits per second) or ‘M’ suffix (megabits per second). If tx-rate is not specified, rx-rate serves as tx-rate too. The same applies for tx-burst-rate, tx-burst-threshold and tx-burst-time. If both rx-burst-threshold and tx-burst-threshold are not specified (but burst-rate is specified), rx-rate and tx-rate are used as burst thresholds. If both rx-burst-time and tx-burst-time are not specified, 1s is used as default. Priority takes values 1..8, where 1 implies the highest priority, but 8 - the lowest. If rx-rate-min and tx-rate-min are not specified rx-rate and tx-rate values are used. The rx-rate-min and tx-rate-min values can not exceed rx-rate and tx-rate values.
