i try to forward port into client which is fix ip but it is not work
i setup eth1 =>ppoe client mode (ip random from isp)
eth2 eht2 => bridge mode 192.168.0.1-255
You have the ‘NOT’ on your in-interface filter from ppoe checked. I’d just remove it personally since you have the dst-type=local, but a least uncheck the NOT.
